Geoprocessing tasks in Flex
1670
7
08-11-2010 09:32 AM
AronHarris
Does anyone have sample code for doing a Geoprocessing tasks. I have the server side done its just the Flex part I am stuck on like how to call and display it.
RobertScheitlin__GISP
Aron,
   Have you not seen the GP samples like http://help.arcgis.com/en/webapi/flex/samples/index.html?sample=GP_Viewshed ?
AronHarris
Aron,
I have looked at it and played with it. I am having a problem with displaying it back on the map.
Aron,
    Just because you have the GP setup and working in desktop does not mean that you have all the parameters setup correctly for the GP to be published and usable as a service in server. There are some very specific step you have to take for a GP to be ready to publish to server. I cover the steps for start to finish in the thread.
http://forums.esri.com/Thread.asp?c=158&f=2421&t=285944&mc=7
AronHarris
Aron,
Hi Robert,
I did your step by step example which is very nice. I am getting this error (RPC Fault faultString="" faultCode="400" faultDetail="GPTask 'execute' does not exist or is inaccessible). Any idea on what I am missing
DasaPaddock
What is the execution type? If it is "esriExecutionTypeAsynchronous" like this one, then you'll need to call submitJob instead of execute.
http://sampleserver4.arcgisonline.com/ArcGIS/rest/services/HomelandSecurity/Incident_Data_Extraction...
Reference:
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/tasks/Geoprocessor.html
AronHarris
Reference:
I am doing it step-by-step outline in Robert Scheitlin
  GP_Service_Steps2.txt (opens in new window)
its syncronus
<?xml version="1.0" encoding="utf-8"?>
<mx:Application
    xmlns:mx="http://www.adobe.com/2006/mxml"
    xmlns:esri="http://www.esri.com/2008/ags"
    pageTitle="Count ADTs"
    layout="absolute">
    <mx:Script>
        <![CDATA[
            import com.esri.ags.Graphic;
            import com.esri.ags.events.MapMouseEvent;
            import com.esri.ags.geometry.MapPoint;
            import com.esri.ags.tasks.ExecuteResult;
            import com.esri.ags.tasks.FeatureSet;
            import com.esri.ags.tasks.ParameterValue;
      import com.esri.ags.geometry.Polygon;
            import mx.controls.Alert;
            import mx.rpc.AsyncResponder;
     private function GetCount():void
  var pPnt:MapPoint = new MapPoint(myMap.extent.xmin, myMap.extent.ymin);
             var pPnt2:MapPoint = new MapPoint(myMap.extent.xmax, myMap.extent.ymin);
             var pPnt3:MapPoint = new MapPoint(myMap.extent.xmax, myMap.extent.ymax);
             var pPnt4:MapPoint = new MapPoint(myMap.extent.xmin, myMap.extent.ymax);
             var pPoly:Polygon = new Polygon();
             pPoly.addRing([pPnt, pPnt2, pPnt3, pPnt4, pPnt]);
             var gra:Graphic = new Graphic(pPoly);
             var featureSet:FeatureSet = new FeatureSet([gra]);
                var params:Object = {
                    "sf123_shp":featureSet
                gp.execute(params); //,  new  AsyncResponder(onResult, onFault)
                function onResult(gpResult:ExecuteResult = null, token:Object = null):void
                 var pv:ParameterValue = gpResult.parameterValues[0];
                 Alert.show(pv.value.toString());
                function onFault(info:Object, token:Object = null):void
                    Alert.show(info.toString());
                    graphicsLayer.clear();
    </mx:Script>
    <mx:Button x="0" y="0" label="Get Count" click="GetCount()"/>
    <esri:Map id="myMap" zoomSliderVisible="false" height="537" y="21">
        <esri:ArcGISDynamicMapServiceLayer
                     url="http://stangis/ArcGIS/rest/services/Maps/test1/MapServer"/>
        <esri:GraphicsLayer id="graphicsLayer"/>
</esri:Map>
    <esri:Geoprocessor
        id="gp"
        url="http://stangis/ArcGIS/rest/services/GP/gpTest1/GPServer"
        showBusyCursor="true"/>
</mx:Application>
DasaPaddock
The url looks like it's too short. It should be to the task.
