GeocodeServer "reference not set to an instance of an object"
2931
12-06-2010 05:36 AM
KyleDixon
I'm trying to implement a GeocodeServer locator in a flex application and I get error:
[RPC Fault faultString="Server Error - Object reference not set to an instance of an object." faultCode="500" faultDetail=""]
<esri:Locator id="locateTask"
             url="http://[internal IP]/ArcGIS/rest/services/shelby/Shelby_Locator/GeocodeServer"/>
When I paste the url in a browser I get a blank page, which I think is expected, when I remove "/rest" and add "?wsdl" I get a proper wsdl response.
I copied the code from http://help.arcgis.com/en/webapi/flex/samples/index.html... Geometry Service.... Determine spatial relationships. I am replacing the different services with our own.
I'm using ArcServer 9.3.1
RobertScheitlin__GISP
Kyle,
   When you paste http://[internal IP]/ArcGIS/rest/services/shelby/Shelby_Locator/GeocodeServer in a browser you definitely should get a page with info on it. Have you tried to see if pasting http://[internal IP]/ArcGIS/rest/services in a browser brings anything up?
KyleDixon
That did show the service, when I drilled down to it, it was working. I had changed some permissions in C:\arcgisserver\arcgiscache working on something else, that probably fixed it.
BUT, now I'm getting:
[RPC Fault faultString="The required address fields must be specified to find address candidates" faultCode="400" faultDetail="Required field '<i>Street or Intersection</i>' must be specified"]
I'm assuming I need to change the field details in the FLEX call. Different locator style maybe
KyleDixon
That was it, I had to change :
    var myAddress:Object = {
     Address: address.text,
      City: city.text,
      State: state.text,
      Zip: zip.text,
      Country: country.selectedItem
to
     Street: address.text,
      Zone: zip.text
So... the correct answer was to change permissions in C:\arcgisserver\arcgiscache, I granted read/write to agsadmin.
