Geocoder - render a point on the map once result is selected
1232
04-15-2013 02:50 AM
KarlBarker-Ottley
I'm trying to get a graphic to render once a result has been selected from the new geocoder functionality in the latest Flex API. When the result is selected, the map pans to it's location - I would like to have a point shown where this is?
Any help scripting this would be appreciated.
Thanks, Karl
IvanBespalov
For new geocoder component, you must listen its events, to access results.
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="library://ns.adobe.com/flex/spark"
      xmlns:esri="http://www.esri.com/2008/ags"
      pageTitle="Geocoder Component Sample">
 <fx:Script>
  <![CDATA[
   import com.esri.ags.Graphic;
   import com.esri.ags.events.GeocoderEvent;
   import com.esri.ags.geometry.Geometry;
   import com.esri.ags.symbols.SimpleFillSymbol;
   import com.esri.ags.symbols.SimpleMarkerSymbol;
   import com.esri.ags.symbols.Symbol;
   import mx.controls.Alert;
   import mx.rpc.events.FaultEvent;
   protected function onGeocoderResultSelected(event:GeocoderEvent):void
    var symbol:Symbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 24, 0xFF0000);
    var gr:Graphic = new Graphic(event.result.geometry, symbol);
    gr.toolTip = event.result.label + "\n(" + event.result.sourceName + ")";
    gLayer.clear();
    gLayer.add(gr);
   protected function onGeocoderFault(event:FaultEvent):void
    Alert.show(event.message.toString(), "Geocoder fault");
   protected function onGeocoderSearchComplete(event:GeocoderEvent):void
    // do something
 </fx:Script>
 <esri:Map id="map">
  <esri:extent>
   <esri:WebMercatorExtent xmin="-20119163" ymin="1160734" xmax="-1333999" ymax="10416341"/>
  </esri:extent>
  <esri:ArcGISTiledMapServiceLayer/>
  <esri:GraphicsLayer id="gLayer" />
 </esri:Map>
 <esri:Geocoder width="300" height="30"
       top="20"
       horizontalCenter="0"
       map="{map}"
       resultSelected="onGeocoderResultSelected(event)"
       fault="onGeocoderFault(event)"
       searchComplete="onGeocoderSearchComplete(event)" />
</s:Application>
P.S. SDK 4.6, API 3.2 release 19.03.2013
IvanBespalov
This example "Geocode an address" and function onResult(), where map pans to first candidate in results.
the same sample with some changes and function showCandidateOnMap()
      xmlns:mx="library://ns.adobe.com/flex/mx"
      xmlns:esri="http://www.esri.com/2008/ags">
 <s:layout>
  <s:VerticalLayout paddingBottom="15"
        paddingLeft="10"
        paddingRight="10"
        paddingTop="15"/>
 </s:layout>
 <fx:Script>
  <![CDATA[
   import com.esri.ags.events.LocatorEvent;
   import com.esri.ags.events.MapMouseEvent;
   import com.esri.ags.geometry.MapPoint;
   import com.esri.ags.tasks.supportClasses.AddressCandidate;
   import com.esri.ags.tasks.supportClasses.AddressToLocationsParameters;
   import com.esri.ags.utils.WebMercatorUtil;
   import flashx.textLayout.conversion.TextConverter;
   import mx.collections.ArrayList;
   import mx.rpc.AsyncResponder;
   import mx.utils.StringUtil;
   import spark.events.GridEvent;
   [Bindable]
   private var lastFoundAddreses:ArrayList = new ArrayList();
   private function onMapClick(event:MapMouseEvent):void
    locateTask.locationToAddress(event.mapPoint, 100);
   private function onLocationToAddressComplete(event:LocatorEvent):void
    var candidate:AddressCandidate = event.addressCandidate;
    if (candidate)
     showCandidateOnMap(candidate);
    else
     Alert.show("This location does not have a known street address.");
   private function doFind():void
    var params:AddressToLocationsParameters = new AddressToLocationsParameters();
    params.address = { "StreetName": onelineaddress.text, City: "Helsinki", Country: "Finland" };
    params.outFields = ["*"]; //all
    // Use outFields to get back extra information
    // The exact fields available depends on the specific Locator used.
    locateTask.outSpatialReference = myMap.spatialReference;
    locateTask.addressToLocations(params, new AsyncResponder(onResultFunction, onFaultFunction));
    function onResultFunction(candidates:Array, token:Object = null):void
     if (candidates.length > 0)
      lastFoundAddreses.removeAll();
      var infoHtmlString:String = "";
      for (var indexer:int = 0; indexer < candidates.length; indexer++)
       var nextCandidate:AddressCandidate = candidates[indexer];
       if (nextCandidate && nextCandidate.address && nextCandidate.location && nextCandidate.score && nextCandidate.score > 0)
        var obj:Object = new Object();
        obj.candidate = nextCandidate;
        obj.address = StringUtil.substitute("{0}; score is >>> {1}", nextCandidate.address.toString(), nextCandidate.score.toString());
        obj.coords = StringUtil.substitute("X={0}, Y={1}", nextCandidate.location.x.toFixed(0), nextCandidate.location.y.toFixed(0));
        obj.geometry = nextCandidate.location;
        lastFoundAddreses.addItem(obj);
      var addressCandidate:AddressCandidate = candidates[0];
      showCandidateOnMap(addressCandidate);
     else
      Alert.show("Sorry, couldn't find a location for this address"
       + "\nAddress: " + onelineaddress.text);
    function onFaultFunction(info:Object, token:Object = null):void
     Alert.show("Failure: \n" + info.toString());
   private function showCandidateOnMap(candidate:AddressCandidate):void
    var address:Object = candidate.address;
    var candidateMapPoint:MapPoint = candidate.location;
    if (candidateMapPoint.spatialReference.wkid != myMap.spatialReference.wkid)
     candidateMapPoint = WebMercatorUtil.geographicToWebMercator(candidate.location) as MapPoint;
    var myGraphic:Graphic = new Graphic(candidateMapPoint, mySymbol, address);
    myGraphic.id = "graphic";
    myGraphicsLayer.clear();
    myGraphicsLayer.add(myGraphic);
    var htmlText:String = "<b>Address:</b><br>";
    if (address.hasOwnProperty("Address"))
     htmlText += address.Address.toString() + "<br>";
    else if (address.hasOwnProperty("StreetName"))
     htmlText += address.StreetName.toString() + "<br>";
    else
     htmlText += address.toString() + "<br>";
    textArea.textFlow = TextConverter.importToFlow(htmlText, TextConverter.TEXT_FIELD_HTML_FORMAT);
    myMap.infoWindow.label = "Geocode an Address";
    myMap.infoWindow.show(myGraphic.geometry as MapPoint);
    myMap.centerAt(myGraphic.geometry as MapPoint);
    if (lastFoundAddreses != null)
     var updatedLastFoundAddress:ArrayList = new ArrayList();
     for (var ind:int = 0; ind < lastFoundAddreses.length; ind++)
      var obj:Object = lastFoundAddreses.getItemAt(ind);
      var objPoint:MapPoint = obj.geometry;
      var dX:Number = objPoint.x-candidateMapPoint.x;
      var dY:Number = objPoint.y-candidateMapPoint.y;
      var half:Number = 0.5;
      var distance:Number = Math.pow((Math.pow(dX, 2) + Math.pow(dY, 2)), half);
      var distanceToPoint:String = StringUtil.substitute(" ~ {0} m", distance.toFixed(0));
      var updatedObj:Object = new Object();
      updatedObj.address = obj.address;
      updatedObj.distance = obj.distance;
      updatedObj.distance2 = distanceToPoint;
      updatedObj.geometry = obj.geometry;
      updatedObj.coords = obj.coords;
      updatedObj.candidate = obj.candidate;
      updatedLastFoundAddress.addItem(updatedObj);
     lastFoundAddreses.addAll(updatedLastFoundAddress);
   protected function myMap_mouseMoveHandler(event:MouseEvent):void
    var currentMousePoint:MapPoint = myMap.toMapFromStage(event.stageX, event.stageY);
      var dX:Number = objPoint.x-currentMousePoint.x;
      var dY:Number = objPoint.y-currentMousePoint.y;
      var updatedDistance:String = StringUtil.substitute("~ {0} m", distance.toFixed(0));
      updatedObj.distance2 = obj.distance2;
      updatedObj.distance = updatedDistance;
   protected function lastFoundGrid_gridClickHandler(event:GridEvent):void
    if (lastFoundGrid.selectedItem != null)
     var selectedCandidate:AddressCandidate = lastFoundGrid.selectedItem.candidate as AddressCandidate;
     if (selectedCandidate != null)
      showCandidateOnMap(selectedCandidate);
 </fx:Script>
 <fx:Declarations>
  <esri:Locator id="locateTask"
       concurrency="last"
       locationToAddressComplete="onLocationToAddressComplete(event)"
       url="http://tasks.arcgisonline.com/ArcGIS/rest/services/Locators/TA_Address_EU/GeocodeServer"/>
  <esri:SimpleMarkerSymbol id="mySymbol"
         alpha="0.5"
         color="0xFF0000"
         size="19"
         style="circle">
   <esri:SimpleLineSymbol width="2"/>
  </esri:SimpleMarkerSymbol>
 </fx:Declarations>
 <s:Label fontSize="12"
    fontWeight="bold"
    text="Click on map to obtain the address of a location."/>
 <esri:Map id="myMap"
     mapClick="onMapClick(event)"
     mouseMove="myMap_mouseMoveHandler(event)"
     openHandCursorVisible="false">
  <esri:extent>
   <esri:Extent xmin="2730524.567128713" xmax="2826835.222767905" ymin="8425522.38792159" ymax="8477346.69309887"/>
  </esri:extent>
  <esri:infoWindowContent>
   <s:TextArea id="textArea"
      editable="false"
      heightInLines="4"/>
  </esri:infoWindowContent>
  <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/>
  <esri:GraphicsLayer id="myGraphicsLayer"/>
 </esri:Map>
 <s:Panel width="100%"
    top="5"
    title="Find an address">
  <s:layout>
   <s:VerticalLayout horizontalAlign="center" verticalAlign="middle"/>
  </s:layout>
  <!-- Single line geocode -->
  <s:TextInput id="onelineaddress"
      width="95%"
      enter="doFind()"
      text="Koskelantie 5"/>
  <s:Button click="doFind()" label="Find Address"/>
  <s:DataGrid id="lastFoundGrid"
     width="100%"
     gridClick="lastFoundGrid_gridClickHandler(event)"
     dataProvider="{lastFoundAddreses}">
   <s:columns>
    <s:ArrayList>
     <s:GridColumn dataField="address" headerText="Address"/>
     <s:GridColumn dataField="distance" headerText="Distance to cursor" width="200"/>
     <s:GridColumn dataField="distance2" headerText="Distance to last clicked" width="200"/>
     <s:GridColumn dataField="coords" headerText="Coordinates" width="200"/>
    </s:ArrayList>
   </s:columns>
  </s:DataGrid>
 </s:Panel>
</s:Application>
P.S. SDK 4.6, API 3.1 release 12.12.2012
IvanBespalov
 <fx:Script>
  <![CDATA[
    gLayer.clear();
    gLayer.add(gr);
    // do something
 </fx:Script>
 <esri:Map id="map">
  <esri:extent>
  </esri:extent>
 </esri:Map>
       top="20"
       map="{map}"
</s:Application>
