FlexViewer2 Search Widget with point layer
1132
07-09-2010 06:03 AM
JoshuaKalov
I have the new flexviewer and search widget set up with a point layer.  With the graphical search tools, if I draw a polygon around a point, the search finds it.  If I try to just use the "Search by point" and click on my point, the Search can't seem to find it.  Anyone know what could be wrong?  I'm thinking its a click tolerance thing?
RobertScheitlin__GISP
Joshua,
   There is not tolerance built in for the point graphical search so you have to add one on your own like this:
private function searchDrawEnd(event:DrawEvent):void
    event.target.deactivate();
    var geom:Geometry = event.graphic.geometry;
    if(geom.type == Geometry.MAPPOINT)
     //Expand the point by 5 pixels
     var point:MapPoint = geom as MapPoint;
     var xMin:Number = map.toScreen(point).x - 2.5;
     var yMin:Number = map.toScreen(point).y - 2.5;
     var xMax:Number = map.toScreen(point).x + 2.5;
     var yMax:Number = map.toScreen(point).y + 2.5;
     var mp1:MapPoint = map.toMap(new Point(xMin,yMin));
     var mp2:MapPoint = map.toMap(new Point(xMax,yMax));
     var ext:Extent = new Extent(mp1.x, mp1.y, mp2.x, mp2.y);
     var pA:Array = [];
                 var pPoly:Polygon = new Polygon(null,geom.spatialReference);
              pA.push(new MapPoint(ext.xmin,ext.ymin,geom.spatialReference));
              pA.push(new MapPoint(ext.xmin,ext.ymax,geom.spatialReference));
              pA.push(new MapPoint(ext.xmax,ext.ymax,geom.spatialReference));
              pA.push(new MapPoint(ext.xmax,ext.ymin,geom.spatialReference));
     pPoly.addRing(pA);
     queryFeaturesGraphical(pPoly);
    } else {
     queryFeaturesGraphical(geom);
JoshuaKalov
Thanks. I'll have to take a look at editing widgets.
JoshuaKalov
Joshua,
     var pA:Array = [];
     pPoly.addRing(pA);
    } else {
I am getting compile errors with this line:
1046: Type was not found or was not a compile-time constant: Extent. SearchWidget.mxml
1180: Call to a possibly undefined method Extent. SearchWidget.mxml
JoshuaKalov
I got the extent error fixed (needed to add an include).
The search still won't recognize a point when clicking on it no matter what I set the tolerance for.  Maybe it is something else that is causing it not to pick up the point?
Joshua,
   That code works fine for me are you sure your map's spatial reference and your map service are the same WKID?
