Flexviewer template: Base widget does not right after switching to Flash 4 Builder
2091
07-02-2010 06:40 AM
ShaningYu
Honored Contributor
I used Flexviewer 1.3 on Flex Builder 3 for a while.  I just downloaded Flash Builder 4 (trial version), and then imported my previous project.  I compiled it, got several errors, as listed below:
1)  In MagWidget.mxml -
<mx:Canvas xmlns:mx="http://www.adobe.com/2006/mxml"
width="300" height="300"
creationComplete="init()"
mouseDown="mdEvent(event)"
mouseMove="mmEvent(event)"
mouseUp="muEvent(event)"
backgroundAlpha="1.0"
backgroundColor="#FFFFFF"
borderColor="#000000"
borderStyle="none"
borderThickness="0"
clipContent="true">
On the line of clipContent="true"> - Error message: The style 'borderThickness' is only supported by type 'mx.containers.Canvas' with the thems of 'halo'
2) Runtime error:
ArgumentError: Error #1063: Argument count mismatch on mx.graphics::SolidColorStroke/apply(). Expected 3, got 1.
at com.esri.ags.symbol::SimpleFillSymbol/traceExtent()
at com.esri.ags.symbol::SimpleFillSymbol/drawExtent()
at com.esri.ags.symbol::SimpleFillSymbol/drawSolidFillSymbol()
at com.esri.ags.symbol::SimpleFillSymbol/drawFillSymbol()
at com.esri.ags.symbol::SimpleFillSymbol/draw()
at com.esri.ags::Graphic/drawWithSymbol()
at com.esri.ags::Graphic/updateDisplayList()
at mx.core::UIComponent/validateDisplayList()
at mx.managers::LayoutManager/validateDisplayList()
at mx.managers::LayoutManager/doPhasedInstantiation()
at mx.managers::LayoutManager/validateNow()
at mx.core::UIComponent/commitCurrentState()
at mx.core::UIComponent/setCurrentState()
at mx.core::UIComponent/set currentState()
at com.esri.solutions.flexviewer::WidgetTemplate/init()
at com.esri.solutions.flexviewer::WidgetTemplate/___WidgetTemplate_Canvas1_creationComplete()
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at mx.core::UIComponent/dispatchEvent()
at mx.core::UIComponent/set initialized()
at mx.managers::LayoutManager/doPhasedInstantiationCallback()
3) The base widge and scale bar (on the left) appear to be not right (see the image attached).  I guess they are related to the errors in 2).
I wish someone can help for these bugs due to the software updating.  Thanks.
DasaPaddock
You'll need to set your project settings to use Flex SDK 3.5.
See: http://forums.arcgis.com/threads/7476-Errors-amp-Warnings
ShaningYu
Honored Contributor
I tried to change to SDK 3.5 (see the image attached), but the errors are the same after re-building it.
ShaningYu
Honored Contributor
Problem solved by replacing agslib-2.0 by agslib-1.3.
