Flexviewer 2.0 Thematic app help
717
07-21-2010 12:46 PM
LeeAllen
I am trying to implement the Flexviewer 2.0 Thematic mapping viewer. Once activated, there is no way that I can find to turn off the thematic layers. Any idea on how to do this?
MehulChoksey
Yes for the compiled version, there is no way to turn off thematic layers once activated.
however, if you are working with source, try replacing widgetClosedHandler and widgetOpenedHandler with the code below
private function widgetClosedHandler(event:Event):void
                clearSelectionAndHideInfoWindow();
                featureLayer.visible = false;
                sendLegendURL("");
                map.removeEventListener(MapMouseEvent.MAP_CLICK, onMapClick);
                map.removeEventListener(ExtentEvent.EXTENT_CHANGE, onExtentChange);
                var operationalLayerData:Object = ht.find(currentTheme.labelref);
                operationalLayerData = ht.find(currentTheme.labelref);
                if (operationalLayerData)
                    operationalLayerData.visible = false
                    currentTheme.visible = false;
                    previousOperationalLayer = currentOperationalLayer = operationalLayerData.label;
                    /*currentQueryParameter = getCurrentQueryParameter(currentOperationalLayer);
                    if (currentQueryParameter)
                        sendLegendURL(currentQueryParameter.legendurl);
                    else
                        sendLegendURL("");
                ViewerContainer.dispatchEvent(new AppEvent(AppEvent.MAP_LAYER_VISIBLE, operationalLayerData));
            private function widgetOpenedHandler(event:Event):void
                if (featureLayer)
                    featureLayer.visible = true;
                var currentOperationLayerData:Object = ht.find(currentOperationalLayer);
                if (currentOperationLayerData)
                    currentTheme.visible = true;
                    currentOperationLayerData.visible = true;
                    ViewerContainer.dispatchEvent(new AppEvent(AppEvent.MAP_LAYER_VISIBLE, currentOperationLayerData));
                var currentQueryParameter:Object = getCurrentQueryParameter(currentOperationalLayer);
                else
                    sendLegendURL("");
                map.addEventListener(MapMouseEvent.MAP_CLICK, onMapClick);
                map.addEventListener(ExtentEvent.EXTENT_CHANGE, onExtentChange);
