FlexViewer 2.0 LayerList
2910
10
09-01-2010 01:41 PM
MelissaJohnson
I am new to the Flex API and have gotten pretty far with configuring the new flex viewer (I downloaded the version with source) , but I am stuck on the LayerListWidget.  I am trying to set it up to load layers from my dynamic map service.  The dynamic map service displays fine.  I have 3 services under basemaps (in config.xml), an aerial, streets (both tiled), and general data service(dynamic).
I can't figure out what in LayerListWidget.mxml I need to change to read the layers in my dynamic service.  I hooked it up in config.xml:
<widget label="Layer List" x="600" y="400" icon="assets/images/i_layers.png"
          config="widgets/LayerListWidget.xml"
          url="widgets/LayerList/LayerListWidget.swf"/>
and it shows up in the toolbar and when you select it you get:
Application Error
Error:Event Target:[objectHTTPOperation]
Event Type: Fault
Fault Code: Server.Error.Request
Fault Info: HTTP request errror
The Layer List widget comes up but is empty.  Love the sample viewer and appreciate its being made available, but I do wish there were more detailed explanations in the code to help configure it.
I assume it is not able to figure out where the layer is to pull from.  Is there something else I need to change to configure this correctly?  Thanks in advance!
Melissa
SandeepTalasila
Hi Robert,
I've tried to use your code to expand my TOC in layer list widget, but nothing happens. I can't get to expand my TOC automatically, shall I have to add anything in config.xml too for this to work? Thanks.
EDIT: Got it. worked after using validateNow() function.
Melissa,
    If you have the FlexViewer2.0 source code than you just have to add some code to the LayerListWidget.mxml.
<?xml version="1.0" encoding="utf-8"?>
     // Copyright (c) 2010 ESRI
     // All rights reserved under the copyright laws of the United States.
     // You may freely redistribute and use this software, with or
     // without modification, provided you include the original copyright
     // and use restrictions.  See use restrictions in the file:
     // <install location>/License.txt
<viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009"
                   xmlns:s="library://ns.adobe.com/flex/spark"
                   xmlns:mx="library://ns.adobe.com/flex/mx"
                   xmlns:viewer="com.esri.viewer.*"
                   xmlns:toccomp="com.esri.viewer.components.toc.*"
                   widgetConfigLoaded="init()"
                   x="600"
                   y="400">
    <fx:Script>
        <![CDATA[
            import mx.collections.ArrayCollection;
   import com.esri.viewer.components.toc.tocClasses.TocMapLayerItem;
            private function init():void
                toc.map = map;
                toc.isMapServiceOnly = false; //gotta get this from the config file
                toc.excludeLayers = getExcludeLayers();
                toc.excludeGraphicsLayers = true;
    callLater(expandTOC);
   private function expandTOC():void
    toc.openItems = toc.dataProvider.source;
    for each(var item:TocMapLayerItem in toc.openItems) {
     if (item.isTopLevel()){
      toc.expandItem(item, true);
            private function getExcludeLayers():ArrayCollection
                var result:ArrayCollection = new ArrayCollection();
                if (configData && configData.basemaps)
                    // exclude basemaps
                    for (var i:int = 0; i < configData.basemaps.length; i++)
                        result.addItem(configData.basemaps.label);
                if (configXML)
                    // exclude these layers
                    var layers:XMLList = configXML.excludelayer as XMLList;
                    for (var j:Number = 0; j < layers.length(); j++)
                        result.addItem(layers.toString());
                return result;
    </fx:Script>
    <viewer:WidgetTemplate id="wTemplate"
                           height="300"
                           width="300">
        <viewer:layout>
            <s:VerticalLayout gap="8" paddingTop="4"/>
        </viewer:layout>
        <s:Label text="Layer Visibility"/>
        <toccomp:TOC id="toc"
                     height="100%"
                     width="100%"/>
    </viewer:WidgetTemplate>
</viewer:BaseWidget>
