Flex Related Table Widget
3151
08-25-2011 12:37 AM
ShaunWeston
I am using this relate info widget - http://www.arcgis.com/home/item.html?id=4ec33120c9ea4d019fddf722fc34ea3c
to query properties on a land parcel but it doesn't seem to be working correctly with flex.
I have setup my map service as follows:
Table A (List of Parcel IDs and valuation numbers) join to Table B (List of property valuation details, valuation number being the key)
Table A relate to Feature class C (These are the land parcels and Parcel ID is the key here)
So this works fine in ArcMap, when I click on a parcel (feature class C) it shows all the related records from table A.
However when I do this using the Flex widget above, it shows that there is a relationship by bringing up the first table, but when the next table with all the related records from table A comes up, it is blank.
Can anyone help me out here?
RobertScheitlin__GISP
Shaun,
   Do you see the relationships listed for your parcels layer when you go to the REST Services directory?
RogerKoelpin
Shaun,
Hi Robert,
Not sure how the relationships show on the services directory hence the attached. Should the tables listed on the attached be available for query through your widget?
Thanks for ALL your great work - and any help you can offer.
Roger,
   I need to see the bottom of that page. That is where the relates are listed if they are available.
