Flex API Reloading
1481
02-21-2011 06:46 AM
JordanParfitt
I have an application that I recently updated for a client. They are still seeing the old application in their browser even though they have cleared their cache several times.
I found someone else in my office with this problem and having them reload the index.swf fixed the issue but not for my client.
Any ideas why this is happening? Has anyone else experienced this? Same URL for me and the client but we are seeing different things.
Thank you in advance.
-j
Drew
Once the clients browsers cache is cleared you should be able to see the updated application.
I have heard that some IT departments will cache files on a server to save bandwidth so that could be the problem, but it all depends on your network i guess.
One easy way to solve the issue is to change the URL of the application and have the old URL forward to the new URL. This probably not the ideal solution, but it might be worth a test to see if the client can see the new app.
Another test would be to have the user load the new app in a different browser such as FireFox or Google Chrome.
Finally, if nothing works you can add a query string onto the .swf URL defined in your .html page.  You would open the index.html file on the server and where ever you see the file "index.swf" referenced you can change it to "index.swf?123456789"
The ?123456789 SHOULD cause the browser to think its a new file that has never been downloaded before and pull it down from the server. (Don't forget to backup up your index.html file first 🙂 )
Hope this helps,
Drew
