Flex API  2.5 Warnings
1628
03-08-2012 07:28 AM
ionarawilson1
I downloaded the Flex Api 2.5 and created a project and copied all the necessary data into this project, including the library file. However some applications are displaying warnings:
For example
Legend Skin displays " This compilation unit did not have a factoryClass specified in Frame metadata to load the configured runtime shared libraries. To compile without runtime shared libraries either set the -static-link-runtime-shared-libraries option to true or remove the -runtime-shared-libraries option. LegendSkin.mxml /FLEX_API_2_5/src/com/esri/ags/skins Unknown Flex Problem
And 7 other applications such as AttributeInspectorInfoWindowViewonly, EditorSkin, LayerTOC, etc  show "data binding will not be able to detect assignments to length (please see attached image)"
What am I doing wrong? What am I missing? Thank you so much!!!
BjornSvensson
Esri Alum
Those are warnings that you can ignore. The samples still work fine.  This warning was new with the Adobe 4.5 SDK. We've updated our samples for the next release (3.0 Prerelease) using the same solution as sugggested by Sarthak in his post at http://forums.arcgis.com/threads/29750-Flex-SDK-4.5-support?p=103307&viewfull=1#post103307 to get rid of the warning.
BjornSvensson
Esri Alum
ionarawilson1
Thank you for answering that Bjorn. I will take a look at the page you mentioned to see if it gets rid or the warnings and will let you know! Cheers!!!
KarenRobine
Ionara:
What did you do to get rid of that warning message? I have it in one of my widgets and can't figure out how to get rid of it.
