Flex API 1.3 map extent binding
1390
10-28-2010 05:51 AM
SteveLi
I have a custom map component
public class myMap extends Map and I bind the extent to a model:
this.extent = MapData.instance.ext;
I update MapData.instance.ext in my controller, but map doesn't change its extent.
I have other map attributes bound to the same model, they all work fine, only extent I couldn't make work.
Thanks for any insights.
Drew
is this.extent set to be bindable ?
[Bindable]
public var foo:String;
EDIT
Actually, Rethinking your problem�?�.
I guess this.extent is coming from Map itself and is not a custom property.. so it must be bindable already�?�.. hummm
Drew
I did a few test and the only way (in code) that I could do it was like below�?�
I modified it to match your code so there could be some modifications need.. If anything it will give you some clues
override public function myMap()
   super();
   this.addEventListener(FlexEvent.CREATION_COMPLETE, onCreationComplete);
  private function onCreationComplete(event:FlexEvent):void
   BindingUtils.bindSetter(setterFunc, MapData.instance, "ext");
  private function setterFunc(ext:Extent):void
   this.extent= ext;
SteveLi
Thanks for the quick response.
Somehow it's still not working for me through a testing button:
MapData.instance.ext = new Extent(-8560018, 3812354, 333583, 8215127, new SpatialReference(102100));
No change on the map.
   super();
   this.extent= ext;
Drew
another way is to bind in the markup
<ns1:myMap extent="{MapData.instance.ext}"  width="800" height="250">
     <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer"/>
    </ns1:myMap>
