Flex and the iPad
3441
11
08-30-2012 07:05 AM
deleted-user-yA_w_FC9FKe5
I've been working with Flex Viewer which is an awesome program.  However, my boss just informed me that he wants to be able to see any developement work on his iPad.  So as far as I know the Viewer will not work on it.  From what I thought I heard at the conference is that native Flex would work on the iPad so I downloaded Flex Builder and created a simple map.  We tried it on his iPad and it is still asking for adobe flash.
I sent him this link which works on my pc - http://servername/Flex/CompanyGIS/bin-debug/CompanyGIS.html
Did I misunderstand or what am I missing here?
Michael
DasaPaddock
You'll need to create a Flex Mobile application that will be installed on the iPad like any other application.
See:
http://resources.arcgis.com/en/help/flex-api/concepts/index.html#/Mobile_applications_with_Flex/017p...
Thanks for the quick response but that link does not tell me much.  I've done steps 1 -3 per the initial instructions.  Not sure I understand #4.  Do we have a video that walks someone from start to finish on a simple flex app to iPad?
Also, will this be an app like what you find in the app store then and apple has to approve it.  All of our data will be loaded on from our sever and this is meant to be an intranet application.  Can someone help walk me through this a little?  Thanks I am very confused at the moment.
Steps:
1.Open Adobe Flash Builder, choose File > Import Flash Builder Project.
2.Select Project folder, click Browse, and navigate to the downloaded project folder.
3.Add the API Library to the project through Project > Properties > Flex Build Path > Library Path > Add SWC and locate the "agslib-3.0-2012-06-06.swc" library file.
4.Run the application using a simulator or on a physical device. Using the Run Configurations (Run > Run Configuration) you can add a Mobile application and define the Launch Method as appropriate.
DasaPaddock
You don't have to submit your app to the Apple App Store. Instead you can enroll in the iOS Developer Enterprise Program.
Here is Adobe's help on developing mobile Flex apps:
http://help.adobe.com/en_US/flex/mobileapps/index.html
Okay first step is to become a developer which cost $299.  I'm guessing you cannot do a trial test of being a developer huh.
Must be something out there that is simplier then looking through all of that documentation to see how to take my project and put it on a mobile device.  Do we not have some sort of simple walkthrough to take a map from flashbuilder and make it an app to be put on a mobile device.  I was under the impression this was pretty simple.
DasaPaddock
Have you been able to get step 4 working where it runs on your desktop from Flash Builder?
Here's a good blog post on doing Flex iOS development:
http://devgirl.org/2011/06/20/flexair-for-ios-development-process-explained/
You can just pay for the regular $99 Apple iOS dev program and then distribute your app using "Ad Hoc Distribution" for up to 100 devices.
https://developer.apple.com/programs/ios/
So for $99 I could create something that I could put on my iPad certain iPads that I put the UDID code in for.  How will the user see the app?  Will it just pop up in the app store for only that device?
Do you know of any Flex Apps that are out on the apple store that I could download and take a look at?
LloydHeberlie
I don't know of any specific apps that were built with the ArcGIS API for Flex, but if you just want to see a functionality app check out http://flex.org/flexgame/.
Android tablets: https://market.android.com/details?id=air.com.riagora.flexgame
iPad: http://itunes.apple.com/us/app/game-of-flex/id483389384
Source: http://riagora.com/pvt_content/flexgame/FlexGame-source.fxp
Also check out the mobile samples in the Tour de Flex app (http://flex.org/tour)
[ATTACH=CONFIG]17408[/ATTACH]
DasaPaddock
You would need to distribute the ipa file internally and the user would add it to their iTunes library and then sync it to their iPad.
