Flex 4 map.addChild(element) with constraints
1028
07-15-2010 02:27 AM
LukeEvans
I'm currently trying to add a couple of things (north arrow and copyright information) as children of a Map object.  The north arrow and copyright info components both have constraint values set.  I've tried using
setConstraintValue("bottom", 40) and bottom = 40 for these but to no effect.  The child items just get added at 0,0 it seems.  I can specifically set the x and y values of these and it will move them but that's not really ideal.
Can anyone suggest where I may be going wrong?
Thanks
Luke
ReneRubalcava
Esri Frequent Contributor
Try adding the objects to map.staticLayer
map.staticLayer.addElement(component)
I show an example here adding lat/long coordinates
http://odoe.net/blog/?p=67
The docs for Map state, "StaticLayer is useful for adding legends, logos and other items that should not be moved when the map is panned or zoomed."
That should work.
