Flex 3 Mobile-  Basic Map Enhanced GPS error
1432
07-13-2012 07:10 AM
MikeDahm
I am just starting out on my first mobile application and upgraded from Flex 2.5 to 3. I was using some of the code from the Basic Map Enhanced GPS made by TOVernon to show current location reprojected to the map coordinates. The code worked great in Flex 2.5. When upgrading from Flex 2.5 to 3 I get an error in the geolocation event listener.
I get the following errors:
Multiple markers at this line:
-1067: Implicit coercion of a value of type Array to an unrelated type com.esri.ags.tasks.supportClasses:ProjectParameters.
-1067: Implicit coercion of a value of type com.esri.ags:SpatialReference to an unrelated type mx.rpc:IResponder.
   <fx:Script>
  <![CDATA[
   import com.esri.ags.Graphic;
   import com.esri.ags.events.ExtentEvent;
   import com.esri.ags.events.GeometryServiceEvent;
   import com.esri.ags.events.MapEvent;
   import com.esri.ags.geometry.Geometry;
   import com.esri.ags.geometry.MapPoint;
   import com.esri.ags.geometry.Polygon;
   import com.esri.ags.symbols.PictureMarkerSymbol;
   import com.esri.ags.tasks.supportClasses.BufferParameters;
   import com.esri.ags.utils.WebMercatorUtil;
   import flash.sensors.Geolocation;
   [Embed(source="/assets/gpsA.png")]
   private var m_gpsA:Class;
   [Embed(source="/assets/gpsB.png")]
   private var m_gpsB:Class;
   private var GPSPoint:MapPoint;
   private var pt:MapPoint;
   private var geo:Geolocation;
   //Load GPS icon if GPS is present
   protected function myMap_loadHandler(event:MapEvent):void
    if (Geolocation.isSupported==true)
     //Initialize the location sensor.
     geo = new Geolocation;
     //set update interval
     geo.setRequestedUpdateInterval(5000);
     //add GPS toggle button
     zoomToCurrentLocationImg.source = m_gpsA;
     zoomToCurrentLocationImg.visible = true;
    else
     //do not show a GPS Icon
   //activate the GPS
   protected function locateGPS(event:MouseEvent):void
    if (myGraphicsLayer.numGraphics > 0)
     myGraphicsLayer.clear();
     GPSGraphicsLayer.clear();
     accBorder.visible = false;
     geo.removeEventListener(GeolocationEvent.UPDATE, onUpdate);
    else
     zoomToCurrentLocationImg.source = m_gpsB;
     geo.addEventListener(GeolocationEvent.UPDATE, onUpdate);
   //geolocation event listener
   private function onUpdate(event:GeolocationEvent):void
    var long:String = event.longitude.toString();
    var lat:String = event.latitude.toString();
    var ha:Number = event.horizontalAccuracy;
    accText.text = ha.toString();
    var longnew:Number = Number(long);
    var latnew:Number = Number(lat);
    var GPSPoint:MapPoint = new MapPoint(longnew, latnew);
    GPSPoint.spatialReference = new SpatialReference(4326);
    var outSR:SpatialReference = myMap.spatialReference;
    geometryService.project([GPSPoint as Geometry], outSR);
   //reproject event
   private function projectCompleteHandler(event:GeometryServiceEvent):void
    try
     // Note: As of version 2.0, GeometryService returns geometries (instead of graphics)
     var pt:MapPoint = (event.result as Array)[0]as MapPoint;
     var ptGraphic:Graphic = new Graphic(null,GPSicon);
     ptGraphic.geometry = pt;
     accBorder.visible = true;
     myGraphicsLayer.add(ptGraphic);
     //add buffer code for GPS horizontal accuracy
     var bufferParameters:BufferParameters = new BufferParameters();
     bufferParameters.geometries = [ pt ];
     bufferParameters.distances = [ accText.text ];
     bufferParameters.unit = GeometryService.UNIT_FOOT;
     bufferParameters.bufferSpatialReference = myMap.spatialReference;
     bufferParameters.outSpatialReference = myMap.spatialReference;
     geometryService.addEventListener(GeometryServiceEvent.BUFFER_COMPLETE, bufferCompleteHandler);
     geometryService.buffer(bufferParameters);
     function bufferCompleteHandler(event:GeometryServiceEvent):void
      geometryService.removeEventListener(GeometryServiceEvent.BUFFER_COMPLETE, bufferCompleteHandler);
      for each (var geometry:Polygon in event.result)
       var graphic:Graphic = new Graphic();
       graphic.geometry = geometry;
       graphic.symbol = fillSymbol;
       GPSGraphicsLayer.add(graphic);
     if (zoomToCurrentLocationImg.source == m_gpsB)
      myMap.centerAt(pt)
     else
      //  geo.removeEventListener(GeolocationEvent.UPDATE, onUpdate);
      //  myGraphicsLayer.clear();
    catch (error:Error)
     //Alert.show(error.toString());
 </fx:Script>
 <fx:Declarations>
  <!--GPS accuracy Polygon-->
  <esri:SimpleFillSymbol id="fillSymbol" color="0x81BEF7"  alpha=".5">
   <esri:outline>
    <esri:SimpleLineSymbol width="2" color="0x0040FF"/>
   </esri:outline>
  </esri:SimpleFillSymbol>
  <!--GPS icon-->
  <esri:PictureMarkerSymbol  id="GPSicon" source="@Embed(source='assets/gps.png')"/>
  <s:Fade id="fade" alphaFrom="1"  alphaTo="0" duration="1500"/>
  <esri:GeometryService id="geometryService" showBusyCursor="false" projectComplete="projectCompleteHandler(event)"
         url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"/>
 </fx:Declarations>
Any help would be greatly appreciated.
RobertScheitlin__GISP
Mike,
   The issue is simplly the result of API changes from 2.5 to 3.0 that are documented in the whats new section of the API.
You need to add this import:
import com.esri.ags.tasks.supportClasses.ProjectParameters
and update this function:
            //geolocation event listener                     private function onUpdate(event:GeolocationEvent):void              {                  var long:String = event.longitude.toString();                 var lat:String = event.latitude.toString();                 var ha:Number = event.horizontalAccuracy;                 accText.text = ha.toString();                 var longnew:Number = Number(long);                 var latnew:Number = Number(lat);                 var GPSPoint:MapPoint = new MapPoint(longnew, latnew);                 GPSPoint.spatialReference = new SpatialReference(4326);                     var projParams:ProjectParameters = new ProjectParameters();                 projParams.geometries = [GPSPoint];                 projParams.outSpatialReference = myMap.spatialReference;                 geometryService.project(projParams);             }
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow the steps as shown in the below graphic:
Mike,
MikeDahm
Solved my own problem.  Flex 3 treats the geometry service differently.  Changed the following code:
    const projectParameters:ProjectParameters = new ProjectParameters;
    projectParameters.geometries = [ GPSPoint as Geometry ];
    projectParameters.outSpatialReference = outSR;
    geometryService.project(projectParameters);
MikeDahm
Thanks,  I just found the reference to the change in the geometry service.  Fixed it a bit different but your code was a little cleaner.  Thank you very much.
