flex 3.0
1429
08-07-2012 05:14 PM
VijayashreeN
I downloaded flexviewer 3.0 and I put all the files in place as mentioned in the viewer help documentation and I also downloaded the swc file and placed in the right position and compiled it and I ended up with 100 to 300 errors . I am not sure what the problem is. I am using flashbuilder 4.0 version. Any thoughts please help.
Thanks
vijayashree
RobertScheitlin__GISP
V,
   Glad you got it working but don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow the steps as shown in the below graphic:
Vijayashree,
   Just for future reference this post belongs in the Flex Viewer forum here:
http://forums.arcgis.com/forums/111-ArcGIS-Viewer-for-Flex
The likely issue you are encountering is the requirement to use the Adobe Flex SDK 4.6. You can use Flash Builder 4.0 but you have to manually download and install the 4.6 SDK from the Adobe downloads page.
Here is the getting started documentation:
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Getting_started_for_developers/...
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
VijayashreeN
Thank you Mr.Robert it worked and now I will have to work on the customizing part.
V,
VijayashreeN
V,
Robert I tried to click the arrow last time and  it didn't work but now hopefully it worked.
