Flex 1.3 - BackwardDiagonal is the same as the ForwardDiagonal fill symbol
1327
05-02-2011 05:48 AM
DaviKucharski
I have a procedure in a Flex project using the ArcGIS API for Flex 1.3. I am applying Graphics to a GraphicLayer based on Zip Codes. Some Zipcodes I use the backward symbol, some others I use the forward symbol. Below is how I declared them. My problem is the zip codes are being applied to the correct graphic symbol but when my map comes up, the zip codes have the same (forward) diagonal line graphic. It doesn't seem to put a backward symbol on it even though I set the symbol correctly. Is there an actual backward line or am I doing something wrong?
<esri:SimpleFillSymbol id="defaultFillSymbolForwardDiagonal" color="0x000000" alpha="1" style="forwarddiagonal">
     <esri:SimpleLineSymbol color="0x000000" width="2" alpha="1" style="solid" />
</esri:SimpleFillSymbol>
<esri:SimpleFillSymbol id="defaultFillSymbolBackwardDiagonal" color="0x000000" alpha="1" style="backwarddiagonal">
SarthakDatt
Hey Davi,
This was a known issue in version 1.1 of the api, but was fixed in version 1.2. Can you double check if you are using the right version?
For reference: http://resources.esri.com/help/9.3/arcgisserver/apis/flex/help/index.html#whats_new.htm, look under the 1.2 release notes
DaviKucharski
Hey Davi,
You were correct. I was on 1.1. Thank you.
