FindParameters:layerDefinitions
2297
12-17-2010 01:41 AM
TonyCollins
Could someone just confirm that the layerDefinitions property in FindParameters is for Server 10 only?
If so, it would be helpful if the documentation @ http://help.arcgis.com/en/webapi/flex/apiref/index.html coud be updated to reflect this.
Is there any way in 9.3.1 using a findtask to acheive the same functionality?
DasaPaddock
Yes, this requires 10:
http://help.arcgis.com/en/arcgisserver/10.0/apis/rest/find.html
Thanks for letting us know that this is missing from the API docs.
Would it be possible for you to use the QueryTask instead even though this means a separate request per layer?
TonyCollins
Thanks for that, just wanted to be sure. Unfortunately there are about 10 layers to query which I would guess is much slower?
Just another reason to note down for moving to 10 :o|
BjornSvensson
Esri Alum
Just FYI that the documentation have been updated with this information, as well as some similar places where the "ArcGIS Server 10 is required" info was missing.
FindParameters - layerDefinitions
FindParameters - maxAllowableOffset
IdentifyParameters - layerDefinitions
IdentifyParameters - layerTimeOptions
IdentifyParameters - maxAllowableOffset
IdentifyParameters.html - timeExtent
Query - maxAllowableOffset
Query - objectIds
Query - timeExtent
Thanks for helping us make the documentation better 🙂
