Finding the center of an polygon?
1058
02-18-2013 11:41 AM
stevemclaughlin
Is there an easy way of finding the center point of a polygon that is defined with lat/long points?
AnthonyGiles
Honored Contributor
Steve,
You should be able to use graphic.extent.center ,see:
http://resources.arcgis.com/en/help/flex-api/apiref/index.html
Regards
Anthony
stevemclaughlin
Great, thanks!  I knew there must be an easy way!
AnthonyGiles
Honored Contributor
Steve,
Please don't also forget to mark the post as answered by checking the tick on the answer,
Thank you,
Anthony
