Find Route Location
778
07-29-2010 09:32 AM
PatrickAdesso
I have an interesting problem that I can't quite overcome.  I have a 300+ mile polyline that is also a route published as a map service in ArcGIS 10.
I need to replicate the functionality that is in ArcMap where a user can provide a route location and the application will zoom to that spot as described here.
I tried a workaround of querying the line to get it in my graphics layer then looping through the paths array, calculating distances and returning a point when the distance exceeded the input but the result wasn't accurate enough.
private function getRouteLocation(location:Number, paths:Array):MapPoint
    tempDist = 0;
    var locationPoint:MapPoint = new MapPoint();
    for(var i:int = 0; i < paths.length; i++)
     for(var j:int = 0; j < paths.length; j++)
      if(i < paths.length && j <= paths.length - 2)  // normal
       tempDist =
        tempDist + Math.sqrt( Math.pow( (paths[j + 1].x - paths.x), 2)
         + Math.pow( (paths[j + 1].y - paths.y), 2) );
      else if(i<=paths.length - 2 && j == paths.length) //end of an inner array
       tempDist =
        tempDist + Math.sqrt( Math.pow( (paths[i + 1][0].x - paths.x), 2)
         + Math.pow( (paths[i + 1][0].y - paths.y), 2) );
      locationPoint = paths;
      if(tempDist >= location)
       return locationPoint;
Any help is appreciated!
Patrick
