Fields of Feature Layer
2766
7
10-29-2010 07:56 AM
PaulSchneider
I an trying to add the fields of a feature layer to a combo box and am running into what seems like a silly simple problem.   I have created the FeatureLayer object but when I try to access the fields I get nothing.  Below is my code:
var fLayer:FeatureLayer = new FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/SanFrancisco/311Incidents/MapServer/1");
if (fLayer)
[INDENT]var fldArr:Array = fLayer.layerDetails.fields;
Alert.show(fldArr.toString());  //....NOTHING!!....
/* if working... do this...
var fldAL:ArrayList = new ArrayList(fldArr);
cboField.dataProvider = fldAL;
*/[/INDENT]
Any thoughts?
JustinGreco
It looks like you are trying to get the fields from a table, not a feature layer.  The layer with an index of 1 is a table, try using the layer with an index of 0 instead.
If you do want to get the fields from the table with index 1, then you need to use fLayer.tableDetails.fields instead of fLayer.layerDetails.fields.
PaulSchneider
Still nothing...
JustinGreco
You need to wait for the feature layer to load before you can access the fields.   So you need to add a LayerEvent.LOAD listener to fLayer.
Also if you want to get the field names, you need to loop through each field and push the name value to the array.
PaulSchneider
That did it... thanks!!
lifeEsri
hello 🙂
I have the same pb when i try this Alert.show(fldArr.toString());  it's not working
'featurelayer0' .
thank you for the help
RobertScheitlin__GISP
life Esri,
   You need to use
import mx.utils.ObjectUtil;
Alert.show(ObjectUtil.toString(fldArr));
lifeEsri
life Esri,
   You need to use
thank you but still nothing ..
ok my pb is
I would like to create a combobox that listed the layers of my service in arcgis server and publish and create another combobox which contains the list of fields in each layer selected in the first combobox
and thank you in advance.
