Features used in 2.5 API not displaying in 3.0 API
1604
06-21-2012 11:38 AM
MichaelSmith2
I am trying to update a map application that was built using the 2.5 version of the Flex API to version 3.0. The problem is that data served by ArcGIS Server 10.0 does not display in the new application based on the 3.0 API. From what is posted in the documentation related to the 3.0 API it looks like configuring base and operation layers looks the same.
I know the map services delivered by ArcGIS Server are working because the 2.5 API version in Flash Builder displays the features. The 2.5 and 3.0 API versions of the application are both on the same Windows 2003 server, and both are loaded into Flex Builder 4.5.1. Both versions of the application are referencing the same ArcGIS Server map services.
Software used:
ArcGIS Server 10.0 (feature server)
Flex Builder 4.5.1
ArcGIS Flex Viewer 3.0 source
ArcGIS for Flex 3.0 API
agslib-3.0-2012-06-06.swc
A text file of the MAP portion of config.xml is attached.
- Michael
DasaPaddock
Are you compiling with Flex SDK 4.6?
DasaPaddock
MichaelSmith2
That was it. I was using the wrong version of Flash Builder.
daewoongkim
what is a correct builder version?
RobertScheitlin__GISP
The version of Flash Builder is not important it is the version of the Adobe Flex SDK that matters and for that you need 4.6.
