FeatureLayer not showing in EditWidget
3184
14
12-20-2010 05:45 AM
RichardHolloway
I have my Feature service set up.  I have given edit permissions to the service.  The mapservice is setup as a operational layer.  Do I also add another layer with the featureservice or do I add it as a layer in the Edit Widget?  Not sure what the step by step instructions are on this part.
RichardHolloway
As stated earlier.
"I have my Feature service set up. I have given edit permissions to the service. The mapservice is setup as a operational layer. Do I also add another layer with the featureservice or do I add it as a layer in the Edit Widget? Not sure what the step by step instructions are on this part. "
AniketWani
1. Have your feature service in operational layer section of config.xml. No need to add map service unless you want it for some other reason.
2. Open Edit widget. It will make all editable feature layer visible and populate templates.
Here is the document that talks about edit widget behavior in detail.
http://help.arcgis.com/en/webapps/flexviewer/help/widgets/edit_widget.htm
You might want to upgrade to viewer 2.2 as undo/redo functionality is added in this release.
RichardHolloway
In the attachment I included on earlier response does the featureservice look ok in the config.xml?
AniketWani
It looks good. Did your edit widget worked with default arcgisonline services?
RichardHolloway
Did not try that yet.  Will do that as a test.
