FeatureLayer does not scale to changes in map scale
3161
08-27-2010 09:21 AM
JeffGermain
Featurelayer is not behaving as expected in release build when applying a DefinitionExpression and using either MODE_ON_DEMAND or MODE_SNAPSHOT.
FlashBuilder 4:
- Works properly in debug build
- Does not work in release build
The featurelayer:
mode = MODE_ON_DEMAND // MODE_SNAPSHOT - neither update when map scale changes
contains points. On demand should reapply definition at new extent. Snapshot should have fetch all features for the layer.
The workflow:
Map is zoomed to a county boundary. A definition query is applied to the featurelayer based on some criteria. Features in visible extent are correctly returned and rendered.
Zoom in or out 1 or more levels and featurelayer DOES NOT refetch features or properly scale itself. The layer just never updates. It does pan correctly though.
See screenshots attached.
by Anonymous User
Not applicable
Original User: dpaddock
It is strange that you're seeing a difference between debug and release builds. It may be a security issue. What are the url's you're using when you run each build? Can you provide source code that duplicates this issue?
JeffGermain
Debug:  using ASP.NET development server
http://localhost:3000/PublicViewer/flex_bin/index.html
Release:  IIS
http://localhost/txwrapr/index.html
I can send you the source offline if you provide me an email. Let me know...
by Anonymous User
Not applicable
Sure, my email is my username (dpaddock) at esri dot com.
