Export to Excel and blank records instead of records with zeros
2309
8
11-29-2012 07:09 AM
ionarawilson1
Hi guys,
I am using an excel library  to create a tool that saves the datagrid to an excel file. However if the records are blank, the excel shows zeros, instead of blank records. How would I change the code so the blank records show up as blank? Thank you
Here is the link to the library
http://code.google.com/p/as3xls/
and here is the code snippet
     CursorManager.setBusyCursor();
     sheet = new Sheet();
     var dataProviderCollection:ArrayCollection = excelgrid.dataProvider as ArrayCollection;
     var rowCount:int = dataProviderCollection.length;
     sheet.resize(rowCount + 1,excelgrid.columnCount);
     var columns:Array = excelgrid.columns;
     columns.splice(0, 1) // to delete the first column which is the number of each record , because this field has no datafield, the excel
      //function does not work if we include it in the table like it is included now
     var i:int = 0;
     for each (var field:DataGridColumn in columns)
      fields.push(field.dataField.toString());
      sheet.setCell(0,i,field.dataField.toString());
      i++;
     for(var r:int=0; r < rowCount; r++)
      var record:Object = dataProviderCollection.getItemAt(r);
      /*insert record starting from row no 2 else
      headers will be overwritten*/
      insertRecordInSheet(r+1,sheet,record);
     var xls:ExcelFile = new ExcelFile();
     xls.sheets.addItem(sheet);
     CursorManager.removeBusyCursor();
     var bytes: ByteArray = xls.saveToByteArray();
     var fr:FileReference = new FileReference();
     fr.save(bytes,"DirectoryofForestProductsIndustries.xls");
    else
     Alert.show("Make sure your search produces any results before using this tool");
RhettZufelt
MVP Notable Contributor
It is possible that before populating the field, you could use the as3xls functions to format that field as text.
Excel might not interpret the blanks as zeros.
Otherwise, I would put a trace statement in there and find out exactly what is being sent as zeros.
If blanks are zeros, but spaces or nulls are not, you might try something like the coding in red below.
     var i:int = 0;
      i++;
           trace("record = ",record);
                                           if (record == ""){
                                                    record = " ";    // or set record = null;   to see if something works
    else
ionarawilson1
Hi Rhett,
Thank you so much for helping me. This is I what I see when I use your code:
record =  [object Object]
What should I do? Thanks
ionarawilson1
By the way, I got 346 lines of that, all the records on my database
ionarawilson1
If I set it to null, I get no records traced
 if (record == null )
 record = " ";  }
RhettZufelt
Now that I slow down and look at it, of course that is what you would get trying to just put a trace on an object.
I don't have a way to test or dive into this, but my thinking was to see if you could go to the part of the code that is building/populating the record object and trace the values being loaded into it.  If it is actually passing the zeros, you could if/then change them there.
If it is being populated with blanks here, then you would know that it is getting changed elsewhere (I.e, somewhere in the Excel formatting or such) and could go from there.
R_
ionarawilson1
Thank you Rhett. I believe the problem is when the excel is created because in another function when a data-grid is created the values are blank as in the original database. But I don't see anywhere on the function to create the excel something that would change the nulls to zero.
     var i:int = 0;
      i++;
                                           if (record == ""){
    else
RhettZufelt
So, what is the data type of the fields that are changing blanks to zeros?
Does this just happen when the input data is type string, smallInteger, double, etc, or does it just happen with one data type?
R_
DougBrowning
MVP Esteemed Contributor
I am not sure if this will help but when I did a Python Excel script there was a way to check the Excel "cell_type" which is equal to 0 when the cell is blank.
