Export PDF Widget with GP service by DavidSpriggs
2653
08-18-2011 07:23 AM
AlexanderMena
Got it working (async) but I am also having a problem with layer visibility. None of my selectable layers are being captured.
Any idea on how I can fix this?
Thank you.
Note: In arcMap the funcionality is ok, but in rest show me the PDF without the image of map (only the legend and title).
attached the PDF created.
This is the log message in rest services:
Job Messages:
    esriJobMessageTypeInformative: Submitted.
    esriJobMessageTypeInformative: Executing...
    esriJobMessageTypeInformative: Executing (ExportToPDF): ExportToPDF 706885 1373903 710696 1376668 21897 11252 {"Pozos":true,"Mapa Calles":true,"ViasPrincipales":true,"World Street Map":true,"Construcciones":true,"Lotes":true,"ViasSecundarias":true,"Otros Drenajes":true,"Fincas":true,"Rios":true,"Municipios":true,"Drenajes Primarios":true,"Drenajes Terciarios":true,"Cable Vias":true,"FiltroImagen":true,"Drenajes Secundarios":true} Landscape8x11 false Title "Feature Set" "Feature Set" "Feature Set"
    esriJobMessageTypeInformative: Start Time: Thu Aug 18 10:10:23 2011
    esriJobMessageTypeInformative: Running script ExportToPDF...
    esriJobMessageTypeInformative: Collecting input parameters
    esriJobMessageTypeInformative: Loading Map Style
    esriJobMessageTypeInformative: Processing Map Extent
    esriJobMessageTypeInformative: Old extent: 713306.20926 1375163.74453 714002.301876 1375780.78863
    esriJobMessageTypeInformative: New extent: 706885.0 1373903.0 710696.0 1376668.0
    esriJobMessageTypeInformative: Setting Scale
    esriJobMessageTypeInformative: Setting Visible Layers
    esriJobMessageTypeInformative: Antes de
    esriJobMessageTypeInformative: Entra
    esriJobMessageTypeInformative: Layer not set: Points
    esriJobMessageTypeInformative: Layer not set: Lines
    esriJobMessageTypeInformative: Layer not set: Polys
    esriJobMessageTypeInformative: Layer not set: MAPAS_BASE/CB_MAPA_BASE
    esriJobMessageTypeInformative: Layer not set: Municipios
    esriJobMessageTypeInformative: Layer not set: Rios
    esriJobMessageTypeInformative: Layer not set: ViasPrincipales
    esriJobMessageTypeInformative: Layer not set: ViasSecundarias
    esriJobMessageTypeInformative: Layer not set: FiltroImagen
    esriJobMessageTypeInformative: Layer not set: MAPAS_BASE/CB_INFRAESTRUCTURA_FINCA
    esriJobMessageTypeInformative: Layer not set: Pozos
    esriJobMessageTypeInformative: Layer not set: Construcciones
    esriJobMessageTypeInformative: Layer not set: Lotes
    esriJobMessageTypeInformative: Layer not set: Drenajes Primarios
    esriJobMessageTypeInformative: Layer not set: Drenajes Secundarios
    esriJobMessageTypeInformative: Layer not set: Drenajes Terciarios
    esriJobMessageTypeInformative: Layer not set: Otros Drenajes
    esriJobMessageTypeInformative: Layer not set: Cable Vias
    esriJobMessageTypeInformative: Layer not set: MAPAS_TEMATICOS/CB_FINCA
    esriJobMessageTypeInformative: Layer not set: Fincas
    esriJobMessageTypeInformative: Layer not set: MAPAS_TEMATICOS/CB_GRUPO_ECONOMICO
    esriJobMessageTypeInformative: Layer not set: MAPAS_TEMATICOS/CB_COMUNALES
    esriJobMessageTypeInformative: Layer not set: MAPAS_TEMATICOS/CB_ZONAS_ASISTENCIA_TECNICA
    esriJobMessageTypeInformative: Layer not set: MAPAS_TEMATICOS/CS_SUELOS
    esriJobMessageTypeInformative: Layer not set: Suelos
    esriJobMessageTypeInformative: Layer not set: MAPAS_BASE/CB_IMAGEN
    esriJobMessageTypeInformative: Layer not set: World_Imagery
    esriJobMessageTypeInformative: Layer not set: MAPAS_BASE/CB_MAPA_CALLES
    esriJobMessageTypeInformative: Layer not set: Mapa Calles
    esriJobMessageTypeInformative: Saving as PDF
    esriJobMessageTypeInformative: Scratch WS C:\DOCUME~1\ARCGIS~1\LOCALS~1\Temp\geoprocesamiento\cb_exportar_pdf_gpserver\j596ce7615c5742249698d1cff498be71\scratch
    esriJobMessageTypeInformative: Finished
    esriJobMessageTypeInformative: Completed script ExportToPDF...
    esriJobMessageTypeInformative: Succeeded at Thu Aug 18 10:13:33 2011 (Elapsed Time: 3 minutes 10 seconds)
    esriJobMessageTypeInformative: Succeeded.
DavidSpriggs
Usually this is due to the group layers not being turned on in the MXD template. The best approach is to have all group layers turned on in the mxd and only the actual featureclasses turned off. The layers that get sent from the web app to the service in the layersList object are the actual feature layers, not group layers, thus the need to have all group layers turned on in the MXD template.
