Export attribute table to excel file
7721
8
05-03-2010 09:42 PM
srinim
Hi all,
           May i know how to do an executable file that should export a layer's attributable table to excel file?
Thanks
CaseyBentz
I posted some information on this a few weeks ago.
http://forums.arcgis.com/threads/2784-New-Export-to-Excel-from-Datagrid?highlight=excel
I have attached a new flex project archive that might work.
Casey Bentz
CaseyBentz
My zip files do not appear to be working.  Here is another try.
Casey
CaseyBentz
I am out of ideas.  If you want the sample project I have give my your email address and I will sent it to you.
Casey
KentMarten
There are 2 script tools available from the Geoprocessing Model and Script Tool Gallery for Exporting to Excel.
Both tools export to the .xls format.
Option #1 - Export to Excel or CSV
Option #2 - Export to Excel or HTML
You will need to have Microsoft Excel installed to use this script tool.
JENNIFERHIGGS
Casey
This exactly what I needed, thanks.
BiniamTes
Hello HIGGS,
I want also to export the whole attribute table to excel. may be this is simple question , would you pls share me how it worked with you. I am using ArcGIS 10. and when i could not figure out how to link this with ArcMAP.
thanks .
Biniam
DHB
What new parameter do I have to add to the option I (table to excel)???
DHB
