Execute SOE
1690
6
01-24-2012 06:17 AM
NoloVegis
I have been trying to figure out the best way to execute a Server Object Extension on one of my rest mapserver services.
The extension takes two arguments. 1. wkid 2. featureset and returns a String.
Do I just use something like the HttpService or does the Flex API contain a better method like the gp objects?
I'm using Flex API 2.4
The SOE was writen in C#.
Nolo
IvanBespalov
Nolo,
no (I did not found any).
Use HttpService (we used it).
IvanBespalov
Nolo,
NoloVegis
Thanks, I'll us HTTPService.
LloydHeberlie
Nolo
Hi Nolo,
There will be some samples illustrating how to do this with the 3.0 samples, which aren't public yet.  Are you still having issues with this?  I can share the samples with you if you would like?
Lloyd
Esri Flex Team
NoloVegis
Lloyd,
I ended up going with the HTTPService and it seems to be working well, but if you wouldn't mind posting a sample it may be better then what I have or might help someone else.
Brett
LloydHeberlie
Lloyd,
Brett
Brett,
We're getting very close in finalizing the samples, hopefully I can post them within a couple of weeks.
Lloyd
Esri Flex Team
LloydHeberlie
Brett,
Lloyd
Esri Flex Team
Brett,
You can find the sample code that will be released with ArcGIS API 3.0 for Flex on ArcGIS.com (ArcGIS for Flex Elevations SOE)
Lloyd
Esri Flex Team
