Error in Printing the map
3765
02-13-2012 04:56 AM
Mohammed_YassineAYACHE
Hi EveryBody !
I'm trying to create a widget for printing, like the one existing in the viewer. the problem is when I print the map, I get only a small part of it.
Attached the source code of the widget and a snapshot of the problem occured.
could you please show me what is wrong in my code ?
for your info, when I put the code of the function printMap() in the same file as the map (the main component), it works nice !
I think the problem is solved. I just changed these lines :
this.addElement(printBox);
and
this.removeElement(printBox);
by :
this.parent.addChild(printBox);
and
this.parent.removeChild(printBox);
Attached the modified version of the test project if someone want to use it.
I'll be very thankful for any advise to improve this widget.
by Anonymous User
Not applicable
Original User: rscheitlin
Mohammed,
   I tested your code and got it to produce a whole map without changing anything... How are you calling the code you provided?
private var printWin:PrintWidgetWindow;
            private function showPrint():void
                printWin = PopUpManager.createPopUp(this, PrintWidgetWindow,false) as PrintWidgetWindow;
                printWin.map = myMap;
                PopUpManager.centerPopUp(printWin);
Hi Robert,
I'm calling the printWidget within a toolsController like this :
<?xml version="1.0" encoding="utf-8"?>
<s:Group xmlns:fx="http://ns.adobe.com/mxml/2009"
   xmlns:s="library://ns.adobe.com/flex/spark"
   xmlns:mx="library://ns.adobe.com/flex/mx">
 <fx:Script>
  <![CDATA[
   import com.esri.ags.Map;
   import mx.events.CloseEvent;
   import mx.managers.PopUpManager;
   [Bindable]
   public var printWidgetOpen:Boolean = false;
   private var printWid:PrintWidget;
   public var map:Map;
   protected function hgroup1_rollOutHandler(i:Image):void
    i.width = 30;
    i.height = 30;
   protected function hgroup1_rollOverHandler(i:Image):void
    i.width = 45;
    i.height = 45;
   protected function printIcon_clickHandler(event:MouseEvent):void
    if(!printWidgetOpen){
     printWid = PopUpManager.createPopUp(parent, PrintWidget,false) as PrintWidget;
     printWid.map = map;
     printWid.addEventListener(CloseEvent.CLOSE,printCloseHandler, false, 0, true);
     PopUpManager.centerPopUp(printWid);
     printWidgetOpen = true;
   protected function printCloseHandler(event:CloseEvent):void{
    printWidgetOpen = false;
 </fx:Script>
 <s:BorderContainer width="20" height="160" cornerRadius="10" backgroundAlpha="0.8" backgroundColor="#333333" borderAlpha="0.9" borderColor="#222222" borderStyle="solid" borderVisible="true" borderWeight="3">
  <mx:VBox width="100%" height="100%" horizontalAlign="left" verticalAlign="middle">
   <!--Print Button-->
   <s:HGroup width="25" height="30"
       gap="2"
    <s:Line id="printLine" height="25"
      includeInLayout="{printWidgetOpen}"
      visible="{printWidgetOpen}">
     <s:stroke>
      <s:SolidColorStroke caps="square" color="#ede00a" weight="2"/>
     </s:stroke>
    </s:Line>
    <mx:Image id="printIcon" resizeEffect="Resize"
        width="30" height="30"
        buttonMode="true"
        smoothBitmapContent="true"
        useHandCursor="true"
        source="@Embed('assets/images/i_print.png')"
        click="printIcon_clickHandler(event)"
        toolTip="Impression"
        rollOut="hgroup1_rollOutHandler(printIcon)"
        rollOver="hgroup1_rollOverHandler(printIcon)"/>
   </s:HGroup>
  </mx:VBox>
 </s:BorderContainer>
</s:Group>
and the toolsController is called in the main component like this :
<widgets:ToolsController map="{mainMap}" left="30" bottom="60" />
by Anonymous User
Not applicable
Original User: yassine.dev
I built a simple project to demonstrate the problem I have, it is attached to this post.
NB: when I execute this project using the Flex SDK 4.1, I get the problem described in my first post. and when I execute it with the SDK 4.6, I get the whole map printed but I don't get the copyright label !
and
by :
and
