Error in Flex API 2.1 Layer List
1158
10-12-2010 09:56 AM
JordanParfitt
Has anyone noticed that there is an error in the default Layer List?
1. Go to URL: http://pages.towson.edu/jparfitt/flex/
2. Open the tree view under "Shoreline Rates of Change"
3. Check OFF "Shoreline Rates of Change" (all sub-layers must be checked)
4. Check OFF each of the three sub-layers
5. Check ON "Shoreline Rates of Change" (leave sub-layers off)
BUG: The layers will quickly flash on the screen where as they should have stayed off the whole time.
Has anyone come up with a code fix? I just downloaded this so I have not modified anything. Some of my clients are bit picky and when they notice this they will want it fixed.
Jordan
DasaPaddock
Thanks for reporting this issue. It should be fixed in a future API release. One note is that it doesn't occur if you pan the map before turning the service back on.
