Error #2032
5330
13
08-31-2010 03:49 PM
JustinRiggs
Hi all,
I just installed flexviewer 2.0 Beta on my arcgis server and then manually installed FlashPlayer 10.1 (this server has no internet connection). I went to run the default application and in the browser window I see what looks like a progress bar and then at the bottom of the browser window it says Error #2032.
Has anybody observed this behavior before. Any thoughts on how to resolve the issue?
Thanks!
Justin
JustinRiggs
Justin,
In your number one question don't use localhost spell out your machines name.
Number two depends on the version of IIS you are using is this directly on the server that you are developing? Is it Server 2008? or are you on your desktop and using XP?
It's directly on the server (Windows 2003). I should have mentioned that everything works fine on my desktop - where I got into trouble was in trying to port this over to the server.
Justin
RobertScheitlin__GISP
Justin,
   Yep, that makes a big difference. Once you have done your development and testing on your desktop and you are happy then in FlashBuilder you choose from the "project" menu "Export release build" and then you copy the contents of the bin-release folder over to a virtual directory on the server. Quick IIS tutorial: open IIS on the server expand the websites node and right click Default Web Site and choose new Virtual Directory. Click next in the dialog and give it an alias like FlexViewer and click next and browse to the folder that you copied the bin-release folders contents to. Click next and then ensure that Read and Run scripts (such as ASP) are both checked. Click next and then Finish. That's it your ready to run from the server.
MartinSchejbal
i had the the same problem with Flash applications from my server.
Try this:
http://viveklakhanpal.wordpress.com/tag/error-2032-stream-error/
Martin
JohnZhang
If the "Error #2032" only happens on some machines (when loading the app) but the app works on other machines, then please try to replace the index.swf from a new download of flexviewer.
We had seen this issue with some customers. Hope this helps.
