Error #2032: Stream Error on QueryTask
2616
11-18-2010 05:58 AM
PeteVitt
I'm getting this error when I run my querytask:
Error #2032: Stream Error. URL: http://localhost:2709/query?f=amf&spatialRel=esriSpatialRelIntersects&outFields=AgencyID&returnGeome...
My set up code is:
<esri:QueryTask id="queryTask"
url="http://www.myServer/ArcGIS/rest/services/WaterAgenciesFlex/MapServer/2"/>
[Inject("queryTask")]
   public var queryTask:QueryTask=new QueryTask();
//execute the query:
public function doQueryStreamAll():void
    var aQuery:Query=new Query();
    aQuery.outSpatialReference=theMap.spatialReference;
    aQuery.outFields=["AgencyID", "AgencyName"];
    aQuery.returnGeometry=false;
    queryTask.execute(aQuery, new AsyncResponder(onQuerySuccess, onQueryFail));
Any Ideas what could be happening?  I'm running this OnCreationComplete in an attempt to get all the agencynames and agencyids from a layer and put them in a combo box when the application first opens.  I know that the path to the service is correct and I've run other queries successfully to this service
Thanks
Pete
Drew
PeteVitt
Same error unfortunately
Drew
After looking closer, something is wrong in your code.
You have �??QueryTask�?� declared twice. Once in Markup and once in code�?�
Remove the lines I outlined below.
