Error #1034: Type Coercion Failed - Search widget
837
03-04-2012 03:43 PM
Mohammed_YassineAYACHE
Hi everybody !
I'm trying to use the search widget (Non-SFV/SV) published by
Robert Scheitlin here.
the problem is when using the rectangle drw tool to make a search request, I get this error :
TypeError: Error #1034: Type Coercion Failed : cannot convert Object@109e12e1 to com.esri.ags.geometry.Geometry
after debugging, I released that the object mentioned in the error (
Object@109e12e1) is an array of Geometry !
so how can I deal with this bug ??
RobertScheitlin__GISP
Mohammed,
   So the fix for this issue is to replace this function in the code.
            private function searchDrawEnd(event:DrawEvent):void             {                 event.target.deactivate();                 var geom:Geometry;                 if(event.graphic.geometry is Extent)                     geom = Extent(event.graphic.geometry).toPolygon();                 else                     geom = event.graphic.geometry;                 clearBuffer();                 queryFeaturesGraphical(geom,"esriSpatialRelIntersects",configSearchGraphical[cboLayerGraphical.selectedIndex]);             }
I will update the download on the code gallery soon.
Don't forget to click the Mark as answer check and to click the top arrow (promote) as shown below:
Mohammed,
