Error #1010: A term is undefined and has no properties.
6172
11
02-24-2012 01:30 AM
sherlytobias
private function init():void    {     graphicsLayer = new GraphicsLayer;     map.addLayer(graphicsLayer);     srv.send();    }        private function resultHandler(event:ResultEvent):void    {    myXML = event.result.myXML.entry;           var gArr:Array = [];    var graphics:Array = [];    for each (myObject in data) {     latlong = Number(myObject.point.toString());                 myPoint = new MapPoint(latlong);          var uGraphic:Graphic = new Graphic (myPoint);     gArr.push(myPoint);     graphics.push(uGraphic);    }     var outSR:SpatialReference = new SpatialReference(3857);    geometryService.project(gArr, outSR, new AsyncResponder(projectCompleteHandler, null, graphics));    }        protected function projectCompleteHandler(result:Object, token:Object):void    {     var pRslts:Array = result as Array;     for (var pg:int = 0; pg < pRslts.length; pg++){      var pGeom:Geometry = pRslts[pg];      token[pg].geometry = pGeom;     }     graphicsLayer.graphicProvider = token;    }
please help.
RobertScheitlin__GISP
Sherly,
   Here it is tested. You are going to have to learn a lot more about flex as copy and pasting code you find will somethimes work but you have to have some understanding of what it is doing.
<?xml version="1.0" encoding="utf-8"?> <s:View xmlns:fx="http://ns.adobe.com/mxml/2009"      xmlns:s="library://ns.adobe.com/flex/spark"     xmlns:esri="http://www.esri.com/2008/ags"      title="Map" creationComplete="init()" >     <fx:Script>         <![CDATA[             import com.esri.ags.Graphic;             import com.esri.ags.SpatialReference;             import com.esri.ags.events.GeometryServiceEvent;             import com.esri.ags.geometry.Geometry;             import com.esri.ags.geometry.MapPoint;                          import mx.collections.ArrayCollection;             import mx.rpc.AsyncResponder;             import mx.rpc.events.ResultEvent;                          private function init():void             {                 pointsXML.send();             }             protected function pointsXML_resultHandler(event:ResultEvent):void             {                 var gArr:Array = [];                 var myGraphics:Array = [];                 var x:XML = XML(event.result);                 var pntList:XMLList = x..entry;                 for (var i:int = 0; i < pntList.length(); i++){                     var latlong:Array = pntList.point.split(" ");                     var myPoint:Geometry = new MapPoint(latlong[1], latlong[0], new SpatialReference(4326));                                          var coordGraphic:Graphic = new Graphic(myPoint);                                          gArr.push(myPoint);                     myGraphics.push(coordGraphic);                 }                 var outSR:SpatialReference = new SpatialReference(3857);                 geometryService.project(gArr, outSR, new AsyncResponder(projectCompleteHandler, null, myGraphics));                                 }                                  protected function projectCompleteHandler(result:Object, token:Object):void             {                 var pRslts:Array = result as Array;                 for (var pg:int = 0; pg < pRslts.length; pg++)                 {                     var pGeom:Geometry = pRslts[pg];                     token[pg].geometry = pGeom;                 }                                  graphicsLayer.graphicProvider = token;                              }                      ]]>     </fx:Script>     <fx:Declarations>         <s:HTTPService id="pointsXML" resultFormat="text"                        url="xml/properties.xml" result="pointsXML_resultHandler(event)"/>         <esri:GeometryService id="geometryService"                                url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"/>     </fx:Declarations>     <s:navigationContent>         <s:Button width="80" height="70" click="navigator.popView()" icon="assets/backbutton.png"/>     </s:navigationContent>          <esri:Map id="map">         <esri:extent>             <esri:Extent xmin="-467799" ymin="5253018" xmax="2171419" ymax="6627661"/>         </esri:extent>         <esri:ArcGISTiledMapServiceLayer url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/>         <esri:GraphicsLayer id="graphicsLayer">             <esri:symbol>                 <esri:SimpleMarkerSymbol alpha="0.9"                                          color="0xFFFF00"                                          size="12"                                          style="square">                     <esri:SimpleLineSymbol color="0xDD0000" width="2" alpha="1" style="solid"/>                 </esri:SimpleMarkerSymbol>             </esri:symbol>         </esri:GraphicsLayer>     </esri:Map> </s:View>
Now you need to make this as answered.
Don't forget to click the Mark as answer check and to click the top arrow (promote) as shown below:
sherlytobias
Thank you so much!
