Enhanced Search icon removal
1766
04-18-2011 10:55 AM
NateRose
I'm wondering if there is a quick way to remove the binoculars from showing up on each of the search results on the map.  It's covering up my icons so I'm wondering if there is a way to turn these off.
Thanks
RobertScheitlin__GISP
Nate,
   If you look in my documentation (Enhanced Search Widget XML Configuration.pdf) you will see that you can define your own result symbology. I do not have the option to not use any result symbology though.
NateRose
Robert,
I had an older version of the Search Widget documentation.  I downloaded the updated documentation and I was able to replace it with a transparent image, worked out great.
Nate
