Enhanced Draw Widget Default Colors
2780
07-14-2010 12:59 PM
JayGeisen
I was wondering if anyone knows where you can change the default draw and label colors in Robert Scheitlin's Enhanced Draw Widget?
Jay
TonyCollins
Can't you use selectedColor on the ColorPickers?
Jay
JayGeisen
Tony, could you elaborate a bit please?  Is there somewhere in the code that the defaults can be changed from black (000000) to, say, red?  I know you can use the color picker when you're in the application, but I'm trying to change the defaults.
I've noticed there are two lines in the addGras function that specify colors, but changing the values (to, say, FF0000) does not seem to make any difference.  The lines are below:
var symColor:Number = 0x000000;
var symColor2:Number = 0x000000;
Jay
RobertScheitlin__GISP
Jay,
   Just look in the DrawWidget mxml code and find the mx:ColorPicker 's and set their SelectedColor attribute to the default that you want like Tony said.
JayGeisen
Thanks guys - worked a charm!
jerrysalinas
I am having a similar issue...
I've just noticed the labeling for the measurements no longer display when using the measurement tools. I've recently changed my mapping application from using dynamic services to tiled services. Also, the draw circle tool does not draw at all. I am using 26914 as my UTM WKID. I can draw lines, rectangles, polygons, etc.....but it does not display the measurements when I check the checkbox, "show measurements".
I did fix the issue with the circle being drawn, but no lables are visible regarding measurements
Thanks
***I solved this issue by re-arranging the my basemaps. I guess it had to do with the spatial ref
