embedding a datagrid in a Repeater
1136
12-19-2011 07:02 AM
DebbieAlger
I have had some success placing a datagrid into a repeater, but not total success. I basically want
a Repeater of completed results, within each result there is a datagrid dedicated to the result. I have tried putting arrays into arrays, and arrays into arraycollections, but all the data goes into the first datagrid. This also opens up the next problem, how to get access to each individual result in each datagrid.
Example of what I want.
Result 1
Datagrid with 4 rows of info related to Result 1
Result 2
etc.
thanks,
DebbieAlger
OK, I actually figured out the datagrid in repeater, but now have a problem getting access to the index of each individual item in the datagrid. I can get the index and info of the parent repeater information, but not the datagrid info, such as the checkbox index.
thanks.
BTW, is there a better way for me to show code in these forums???
//==== THIS IS HOW I ACCESS REPEATER INFORMATION ON A CLICK EVENT
private function btnShowCharacterize(evt:Event):void
    Alert.show ("current name - " + evt.currentTarget.getRepeaterItem().wsName);
    Alert.show ("current index - " + evt.currentTarget.repeaterIndices + " open/close - " + openCloseArray[index].toString());
//==== THIS IS THE REPEATER AND DATAGRID AREA
<mx:VBox height="325"  horizontalScrollPolicy="off"  verticalScrollPosition="{this.width - 10}" verticalScrollPolicy="auto"  >
      <mx:Repeater  dataProvider="{wsArray}"  id="wRepeater"   >
       <mx:HRule width="100%" />
       <mx:HBox    >
        <s:Label   text="             "  />
        <mx:Image  click="remove(event )"   source="assets/images/delete_x.PNG"  width="20" height="20"  />
        <mx:Image    click="Export(event )" source="assets/images/export.png"   width="20" height="20" />
        <s:Label   text="{wRepeater.currentItem.wsName}"  styleName="WidgetText"    />
       </mx:HBox>
       <mx:HBox>
       <mx:Image  id="showCharacterize" click="btnShowCharacterize(event)"  source="assets/images/plus.png"  width="15" height="15"    />
       <s:Label   fontWeight="bold" text=" Characterize"  styleName="WidgetText"   visible="true"  />
       </mx:HBox>
       <!-- Datagrid of created watersheds -->
      <!-- <s:Label  text="" styleName="WidgetText" /> -->
          <mx:VBox id="displayDatagrid"  height="0" visible="false" >
       <mx:DataGrid id="datagrid" dataProvider="{wRepeater.currentItem.gridData}"   rowCount="5" styleName="WidgetText" itemClick="dgClick(event)"   >
        <mx:columns>
         <mx:DataGridColumn headerText="Characterization"    dataField="charType" width="125"/>
         <mx:DataGridColumn headerText="Value"    dataField="charValue" width="75"/>
         <mx:DataGridColumn headerText="Select"   dataField="charChkBox" width="50"    itemRenderer="mx.controls.CheckBox" />
        </mx:columns>
       </mx:DataGrid>
       <s:Button    id="btnCharacterize" click="characterize(event)"   label="Calculate Selected Characteristics" width="250"  />
      </mx:VBox>
KenBuja
To show the code, click on the # symbol in the strip above the editor.
