Editing a related table -help- esri sample
2706
11
11-07-2011 04:24 AM
LizDaRos
Hi, I was wondering if anyone has used the sample from esri that allows you to edit a related table? I have the application setup and running using one of my own feature services but I need to add more fields from the related table to edit. This sample only allows you to make edits to the agree_with_incident field by clicking on an image. I'm not sure where I need to add in my others fields that I'd like to edit.
Any ideas would greatly be appreciated!
LizDaRos
I've found some code that uses the same code as the attribute inspector sample to edit related tables. Here is the link-
access-a-relationship-query-through-Attribute-Inspector
I'm also using points instead of polygons so I've switched some on the code in the attribute inspector sample to select the points.
I think I am close to getting this working, I can see the related table information in the attribute inspector popup but it only shows for about half a second then disappears and another blank popup displays.
Attached is my code... can anyone see what the problem is?
RobertScheitlin__GISP
Liz,
   Your issue is that both the roomsLayer and the roomsTableLayer featurelayers are firing the tableSelect_selectionCompleteHandler function.
LizDaRos
That was it, thank you very much Robert!
Now I just need to add a function that adds a new record to the related table. It looks like the code from the Editing a Related Table sample can do this. If that's the right direction then I'm trying to use this function in my application but not having much luck. Any suggestions?
   private function addImage_clickHandler(event:MouseEvent):void
    const roomsTableLayer:Object = {
     object: selectedGraphic.attributes.objectid,
      datetime: new Date().getTime(),
      agree_with_incident: 1
    const roomsTableLayer:Graphic = new Graphic(null, null, roomsTableLayerAttributes);
    const roomsTableLayer:FeatureLayer = new FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/SanFrancisco/311Incidents/FeatureServer/1");
    roomsTableLayer.addEventListener(FeatureLayerEvent.EDITS_COMPLETE, roomsTableLayer_editsCompleteHandler);
    roomsTableLayer.applyEdits([ voteRecord ], null, null);
   private function roomsTableLayer_editsCompleteHandler(event:FeatureLayerEvent):void
    count++;
    peopleCount.text = count + " people think this is important";
Liz,
    You have several coding issue here:
   //And here you are using the same constant name again, this is no good.
    //And here you are using the same constant name again, this is really no good.
    //Now you are trying to apply voteRecord which does not exist in your code to the table
    count++;
LizDaRos
Thanks for looking at it. I guess I was just wondering if the function from that sample would even do what I want? I kind of realized the code I showed wasn't correct and would need some changes.
Liz,
   It looks like it should work.
R__CraigHolmes
Greetings Liz,
I am having difficulty with the final step of adding an additional relate entry.  Did you you have success with this?
Can you share your code?
Craig
LizDaRos
Craig,
No I wasn't able to add an additional relate entry with this flex sample, sorry. Instead I used the Javascript API sample- Citizen Service Request.
I was able to change this sample to just allow the user to create a new record in the related table.
Liz
ionarawilson1
Liz,
I am having a similar issue. Do you think you can share your code to add records to the related table? Thank you!
