Edit without EditorToolbar or Template Picker
1278
09-24-2010 07:56 AM
jamalhanine
Hi, I'm a beginner in flex api (ArcGIS)
how can i add features to SDE geodatabase without using EditorToolbar or Template Picker?
i have an other problem! i can't use "ArcGISTiledMapServiceLayer" i am working with "ArcGISDynamicMapServiceLayer", if any any one khnows how can i use "ArcGISTiledMapServiceLayer"
Thank you.
JoshCalhoun1
Make sure you change the attribute in the config.xml file to "dynamic" instead of "tiled".
See the attachment below.
Hope it helps
JoshCalhoun1
Also,
Are you trying to edit features in ArcGIS Destop? If so, you will need to use the editor toolbar to add features to an SDE database.
