Edit geoprocessing widget error
1859
04-14-2014 02:21 AM
fatizanady
hi everyone,
I tried to run Editing Geoprocessing Widget in my fiewer 3.4.
for editing lines the widget works fine, but when I use the same widget for points and polygon I receive the following error message:
"Unexpected fault:
[FaultEvent fault = [RPC Fault faultString = "Unable to complete operation." faultCode = "400" faultDetail = "Error running the tool."] messageId = null type = "fault" bubbles = false cancelable = true eventPhase = 2]"
we find the widget edit polygon attached below.
Any suggestion will be very appreciated .
BjornSvensson
Esri Alum
Hi zanady,
Do you mean the "Edit" widget or the "Geoprocessing" widget (or some custom widget)?
What does the request being sent in look like?
fatizanady
Hi zanady,
Hi bjorn,
i'm tried to run Editing Geoprocessing Widget that i download in this link: http://www.arcgis.com/home/item.html?id=798746aaabcc4e8f872a321257d8cfd4
i'm used flex viewer 3.4 and arcgis server 10.1.
i have this error when i try to use the same widget for points and polygon.but for lines it work fine!!!!!:
"Unexpected fault:
bjorn me help pealse 😞
