Dynamic service symbols for polygons with outlines do not draw in Layer List widget
911
05-13-2013 03:22 PM
MatthewGubitosa
[ATTACH=CONFIG]24264[/ATTACH]
When a dynamic service with polygon symbols consisting of a 1-pt outline and no fill is used, its swatches do not draw in the Layer List widget - but draw just fine in the actual map.
If the same data is brought into the application from a feature layer, Layer List widget displays the symbols without difficulty.
Is there any solution to this problem?
