Dynamic map service
1314
03-09-2011 01:26 PM
JonPedder
I have code that displays an ESRI tiles map service correct but when I try to display a dynamic map which is published locally it won't display. I've tested that the map does indeed display when I use a simple statement as follows.
<esri:Map>
  <esri:ArcGISDynamicMapServiceLayer url="http://sarserver/MapSAR_Server/rest/services/ANF/MapServer"/>
</esri:Map>
However when I try the following I get a blank screen, might this be as I'm attempting to display multiple dynamic services?
<esri:Map
    id="myMap"
    level="14"
    load="myMap_loadHandler(event)"
    width="100%" height="100%">
     id="assignmentsLayer"
     visible="{toggleAssignments.selected}"
     alpha=".7"
     url="http://sarserver/MapSAR_Server/rest/services/MapSAR_Assignments_Server/MapServer"
</esri:Map>
Thanks in advance
Jon
Drew
<esri:Map>
</esri:Map>
<esri:Map
    id="myMap"
    level="14"
     alpha=".7"
</esri:Map>
Thanks in advance
Jon
First I would check if the service is viewable in the rest services JavaScript viewer. You can do so at the below URL:
Second, I would check if the layers are visible at level="14". Do you have min or max scale levels set in the mxd (or msd). Try removing level="14" and see what comes up.
Finally, I would check to see whats coming back from the server using FireBug or Fiddler.
Drew
JonPedder
Thanks for the tip, unfortunately it didn't work.
Interestingly I can see the map in java via rest and also see it if using a very simple test mxml doc. If I switch to a tiled map hosted by arcgis it display fine, when I switch to dynamic is when I see nothing.
here's the code that works with tiled
   <esri:Map
    id="myMap"
    level="14"
    <!-- based on CA topo service coordinate system
    <esri:extent>
    <esri:Extent id="mainExtent" xmax="499889.034" ymax="3791242.816" xmin="472558.580" ymin="3776222.919">
    <esri:SpatialReference wkid="26911"/>
    </esri:Extent>
    </esri:extent>
    <esri:ArcGISTiledMapServiceLayer
     url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"
     alpha=".7"
Here's the code that fails
<esri:Map
    id="myMap"
    <esri:extent>
     <esri:Extent xmax="410209.212" ymax="3787665.306" xmin="400982.892" ymin="3781910.607">
     </esri:Extent>
    </esri:extent>
     alpha=".7"
Drew
Sounds like a data problem...
Have you checked your MXD to ensure the datasources are valid ?
Are you using SDE, FGDB, PGDB ?
Drew
JonPedder
Found it, it was this line that prevented the dynamicmapservice display properly.
remove that and voila!
Jon
