Dynamic layers not showing after map rotation
3962
8
03-18-2013 07:12 PM
RolandChu
Hi all,
I tried to integrate the new map rotation function in API 3.1 into the FV. It works perfect for the tiled layers.
However, the dynamic layers didn't show unless the angle of rotation is around 0+/-5, 90+/-5, 180+/-5 or 270+/-5 degree.
Did anyone know what's the problem? Thank you.
Here is my code:
<?xml version="1.0" encoding="utf-8"?> <viewer:BaseWidget xmlns:fx   ="http://ns.adobe.com/mxml/2009"         xmlns:s   ="library://ns.adobe.com/flex/spark"         xmlns:mx   ="library://ns.adobe.com/flex/mx"         xmlns:viewer  ="com.esri.viewer.*"        xmlns:components ="com.esri.ags.components.*">    <components:RotationWheel id="wheel"          width="75" height="75"          left="20" top="20"          change="map.rotateTo(wheel.mapRotation, wheel.mapRotation == 0)"          mapRotation="{map.mapRotation}"          skinClass="com.esri.ags.skins.RotationWheelSkin"/> </viewer:BaseWidget>
I just copied this from the sample and please find the RotationWheel and RotationWheelSkin from the samples come with the API.
YannCabon
Cool!
You could fix it actually by setting on the dynamic layers the maxImageHeight and maxImageWidth values to 2048.
This property are automatically set by 10.1 servers' layers.
YannCabon
I can't reproduce the issue with the following code:
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
               xmlns:s="library://ns.adobe.com/flex/spark"
               xmlns:mx="library://ns.adobe.com/flex/mx"
               xmlns:esri="http://www.esri.com/2008/ags"
               xmlns:components="com.esri.ags.components.*"
               minHeight="600"
               minWidth="955">
    <fx:Declarations>
        <!-- Place non-visual elements (e.g., services, value objects) here -->
    </fx:Declarations>
    <esri:Map id="map">
        <esri:ArcGISTiledMapServiceLayer/>
        <esri:ArcGISDynamicMapServiceLayer url="http://sampleserver6.arcgisonline.com/arcgis/rest/services/SF311/MapServer"/>
    </esri:Map>
                              left="48" top="24"
                              mapRotation="{map.mapRotation}"/>
</s:Application>
What is the version of your server?
RolandChu
You're right. In 10.0 sp4 it doesn't work. And then I publish the service to a 10.1 sp1 machine and now it works. Thank you.
YannCabon
Cool!
RolandChu
Cool!
You got the point again. I am using a full HD screen. And when I resize the viewer size smaller, the service on 10.0 can properly shown as well. Thank you so much.
DilsonKitoko
Hello Roland Chu,
Did you managed to integrate the rotate to your Flex Viewer? I'm trying to implent to 3.6 version (AGS 10.2.2), using the Esri sample.
I just copied the code from sample into Flash builder, but I've an error saying that :
Error 1046:Type was not found or was not a compile-time constant:RotationWheel. Below is my code
xmlns:components="com.esri.ags.samples.components.*"
pageTitle="Explore map rotation">
<fx:Script>
import com.esri.ags.samples.skins.RotationWheelSkin
import com.esri.ags.Map;
</fx:Script>
<fx:Declarations>
<s:Rotate id="rotateEffect"
duration="100"
target="{wheel}">
</s:Rotate>
</fx:Declarations>
<s:controlBarContent>
<s:RichText width="100%">
This sample demonstrates how to rotate the map using the
ArcGIS API for Flex. Rotate the wheel to rotate the map.
To reset the map rotation, click the "N" North button on the wheel.
</s:RichText>
</s:controlBarContent>
<esri:Map id="map"
crosshairVisible="true"
level="17"
middleButtonRotationEnabled="true"
wrapAround180="true"
zoomSliderVisible="false">
<esri:center>
<esri:MapPoint x="-10051125" y="4669530"/>
</esri:center>
<esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/>
</esri:Map>
left="20" top="20"
skinClass="com.esri.ags.samples.skins.RotationWheelSkin"/>
</s:Application>
Thanks in advance,
Dilson
DilsonKitoko
Hello Sorry,
I posted the code in wrong why, I was trying to directly use the sample example application as widget structure.
Below is me code for the widget that 'm trying to do. By the way I getting 2 errors:
Syntax error 1084: expecting rightbrace before end of program (below)
</fx:Script>
"1131: Classes must not be nested."  (below)
public class RotationWheel extends SkinnableComponent
<s:Group xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:RotateMap="widgets.RotateMap">
<fx:Script>
<![CDATA[
import com.esri.viewer.AppEvent;
import com.esri.viewer.utils.LocalizationUtil;
import flash.events.Event;
import flash.events.MouseEvent;
import flash.geom.Point;
import flash.geom.Vector3D;
import mx.binding.utils.BindingUtils;
import mx.binding.utils.ChangeWatcher;
import mx.core.UIComponent;
import spark.components.Group;
import spark.components.supportClasses.SkinnableComponent;
[Event(name="change", type="flash.events.Event")]
[SkinState("up")]
[SkinState("overNorth")]
[SkinState("downNorth")]
[SkinState("overWheel")]
[SkinState("downWheel")]
[SkinState("disabled")]
 public static const DEG_PER_RAD:Number = 180 / Math.PI;
public function RotationWheel()
super();
buttonMode = true;
addEventListener(MouseEvent.MOUSE_OVER, mouseOverOutHandler);
addEventListener(MouseEvent.MOUSE_OUT, mouseOverOutHandler);
addEventListener(MouseEvent.MOUSE_DOWN, mouseDownHandler);
addEventListener(MouseEvent.MOUSE_UP, mouseUpHandler);
private var m_globalWheelCenter:Vector3D = new Vector3D();
private var m_originVector:Vector3D = new Vector3D();
private var m_wheelCenterVector:Vector3D = new Vector3D();
private var m_originMapRotation:Number = 0;
private var m_overWheel:Boolean;
private var m_mouseOverNorth:Boolean;
private var m_mouseDown:Boolean;
[SkinPart(required="false")]
public var wheel:Group;
public var north:UIComponent;
private var m_mapRotation:Number = 0;
[Bindable("mapRotationChanged")]
public function get mapRotation():Number
return m_mapRotation;
public function set mapRotation(value:Number):void
if (m_mapRotation != value)
m_mapRotation = value;
if (skin)
skin.invalidateProperties();
dispatchEvent(new Event("mapRotationChanged"));
private var m_map:Map;
private var m_mapRotationWatcher:ChangeWatcher;
public function get map():Map
return m_map;
public function set map(value:Map):void
if (m_map !== value)
if (m_mapRotationWatcher)
m_mapRotationWatcher.unwatch();
m_map = value;
if (m_map)
mapRotation = m_map.mapRotation;
m_mapRotationWatcher.reset(m_map);
else
m_mapRotationWatcher = BindingUtils.bindProperty(this, "mapRotation", m_map, "mapRotation");
override protected function getCurrentSkinState():String
var state:String = "up";
if (m_overWheel)
state = m_mouseDown ? "down" : "over";
state += "Wheel";
else if (m_mouseOverNorth)
state += "North";
return state;
private function stop():void
stage.removeEventListener(Event.ENTER_FRAME, enterFrameHandler);
stage.removeEventListener(MouseEvent.MOUSE_UP, mouseUpHandler);
m_mouseDown = false;
private function mouseOverOutHandler(event:MouseEvent):void
if (!m_mouseDown)
m_overWheel = m_mouseOverNorth = false;
if (event.target === north)
m_mouseOverNorth = true;
else
m_overWheel = true;
invalidateSkinState();
private function mouseDownHandler(event:MouseEvent):void
var globalCenter:Point = wheel.localToGlobal(new Point(wheel.transformX, wheel.transformY));
m_globalWheelCenter.setTo(globalCenter.x, globalCenter.y, 0.0);
m_wheelCenterVector.setTo(m_globalWheelCenter.x, m_globalWheelCenter.y, 0.0);
m_originVector.setTo(event.stageX, event.stageY, 0.0);
m_originVector = m_originVector.subtract(m_wheelCenterVector);
m_originVector.normalize();
m_originMapRotation = m_mapRotation;
stage.addEventListener(Event.ENTER_FRAME, enterFrameHandler);
stage.addEventListener(MouseEvent.MOUSE_UP, mouseUpHandler);
m_mouseDown = true;
private function enterFrameHandler(event:Event):void
var mousePosition:Point = wheel.localToGlobal(new Point(wheel.mouseX, wheel.mouseY));
var newVector:Vector3D = new Vector3D(mousePosition.x, mousePosition.y);
newVector = newVector.subtract(m_wheelCenterVector);
newVector.normalize();
var n:Vector3D = m_originVector.crossProduct(newVector);
var newAngle:Number = Vector3D.angleBetween(m_originVector, newVector) * DEG_PER_RAD;
if (n.z < 0)
newAngle = -newAngle;
newAngle += m_originMapRotation;
if (isNaN(newAngle))
newAngle = 0;
if (Math.abs(mapRotation - newAngle) > 1)
mapRotation = newAngle;
dispatchEvent(new Event(Event.CHANGE));
private function mouseUpHandler(event:MouseEvent):void
stop();
if (Math.abs(mapRotation - m_originMapRotation) < 3)
mapRotation = 0;
</fx:Script>
<s:Group enabled="{map.loaded}"
includeInLayout="{panwheelItem.toolVisible}"
layoutDirection="ltr"
visible="{panwheelItem.toolVisible}">
<s:Button id="wheel"
left="20" top="20"
skinClass="widgets.RotateMap.RotationWheelSkin"/>
</s:Group>
</s:Group>
DilsonKitoko
I almost there. I managed to implement the sample into a widget! By the way, the tool is not interacting with the map. I can rotate the "wheel" , I can click on "N" to center the weehl. But nothing happens in the map. I suspect that it's because I've ommitted the following line from the sample (I didn't figure out how to implement this part into the widget):
<esri:center>
        </esri:center>
    </esri:Map>
Here is my code :
<viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:viewer="com.esri.viewer.*"
xmlns:components="widgets.RotateMap.components.*">
<fx:Script>
<![CDATA[
import com.esri.ags.geometry.MapPoint;
import mx.collections.ArrayCollection;
import mx.events.FlexEvent;
</fx:Script>
<fx:Declarations>
</fx:Declarations>
<esri:Map id="map"
level="17"
</esri:Map>
left="20" top="20"
skinClass="widgets.RotateMap.skins.RotationWheelSkin"/>
Any tip on this issue?
Thanks in advance
Dilson
DilsonKitoko
Question solved, I was totally misunderstanding the concept between a sample and passing into a widget format. I just had to remove the class esr:map and voila, the Rotate Wheel interacts with the my WebGIS application.
