Does the Flex API support *all* KML features?
1274
10-21-2011 04:28 PM
AdamWynne
Is the intent to support all KML features in the Flex API (and viewer)?  It seems that some could not possibly be supported (http://code.google.com/apis/kml/documentation/kmlreference.html)
If not, what subset of features does it support?
I have not been able to find this documentation
AdamWynne
Hopefully someone can provide an answer.  I think this is important.  There are KMLs that seem to not work in the viewer, so I'm wondering what the list of supported KML tags is.
BjornSvensson
Esri Alum
No, not all KML functionality are supported.  (As a sidenote, but not excuse, the same is true for Google Maps, Google Map API and many other KML readers.)   And you're correct there is not any docuemntation on supported (or non-supported KML features), only that "most things should work".
If you have a problem KML, the best way to report it is to follow the instructions in my August 10 post at http://forums.arcgis.com/threads/36062-Flex-API-2.4-KML-support-added-need-sample-of-how-to-add-kml
The most common problems I've seen are listed as "Requirements/Limitations" and "Known issues" in that forum post.
AdamWynne
Hi Bjorn--  Thanks much for the response.  I understand KML is a complex spec and some features just don't make sense in a web viewer.  However, I am working in an environment in which a broad range of users are submitting KML files to be displayed in a flex viewer.  So I want to be able to tell them in advance which features are not supported, so I don't have to go through a lengthy process of troubleshooting each file.  It would be very valuable to flex viewer users to be able to know what features are not supported.
Thanks for your time.
