Displaying marker on ArcGIS map
2213
05-16-2014 04:45 AM
SamarthGupta
Hi everyone,
I am building a flex desktop application for displaying some co-ordinates using ArcGIS Maps. As, i am new to ArcGIS map's, i have been going through API reference, and other things to be friendly.
When i was going through map point to display marker's on map, i wasn't able to find out in which format did map point takes the co-ordinates of the location to display marker.
I have a list of co-ordinates where i wish to show multiple markers i have northings, eastings, latitude, longitude (555388.31, 3455103.45, 31.22878668, 75.581577) respectively which correspond to location some where near "Jalandhar, Punjab, India"
Can, some knows about the format of map point?
KomanDiabate
I think all you need is X and Y coordinates to create mappoints.
Assuming you have you data in an arrayCollection or a tempArray you can add XY data to the map in the following fashion:
for(var i:int=0;i<tempArray.length;i++)
 var obj:Object=tempArray.getItemAt(i);
 var myGraphicPoint:Graphic = new Graphic(new MapPoint(obj.X , obj.Y, new SpatialReference(3857)));
 myGraphicPoint.symbol = pointSymbol;
 myGraphicsLayer.add(myGraphicPoint);
SamarthGupta
I have tried as you suggested, and got i my markers as well. Thanks
But, the problem is that when i placed the latitudes value in x and longitudes value in y markers were scattered all over the map as if positions weren't recognized, i even tried placing my earthing value in x and northing value in y but i got the same result.
I have used this code:
protected function getLocation_resultHandler(event:ResultEvent):void
 if(event.result.information.rmk != "error")
  filterXML = event.result as XML;
  var data:Array = new Array();
  for each(table1 in filterXML.information)
  var myGraphicPoint:Graphic = new Graphic(new MapPoint(table1.lng , table1.lat, new SpatialReference(3857)));
  myGraphicPoint.symbol = pictureMarker;
This code gets me last latitude and longitude which are in table1 as i have already written those correspond to location some where in Punjab, but in AcrGIS map marker is placed some where near Africa
KomanDiabate
This is more than likely a spatial reference issue. Make sure you are using the right Spatial reference . Also make sure X is long and Y is lat.
SamarthGupta
How to decide which spatial reference should i use? Any, reference...
