Display map at specified location
1882
6
02-28-2012 08:17 PM
MohammedIsmail
hi
i want to display the map at the center of the screen
whenever i load a new map service the map should get displayed at the center of the screen
i tried this but its not working
<esri:Map id="MyML" load="MyML.centerAt(new MapPoint(70.0,6.0))">
<esri:ArcGISDynamicMapServiceLayer id="myDynamicService" name="{myURL.selectedItem}"
     load="myDynamicService.defaultVisibleLayers()"
      url="http://gis-server/ArcGis/rest/services/{myURL.selectedItem}/MapServer/" width="100%" height="100%">
</esri:ArcGISDynamicMapServiceLayer>
</esri:Map>
thanks
ISMAIL
RobertScheitlin__GISP
Ismail,
   You can not do it the way you are trying, because the mapservice will likely always get created before the myURL component.
Try this:
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
               xmlns:s="library://ns.adobe.com/flex/spark"
               xmlns:mx="library://ns.adobe.com/flex/mx"
               xmlns:esri="http://www.esri.com/2008/ags">
    <fx:Script>
        <![CDATA[
            import com.esri.ags.events.LayerEvent;
            import com.esri.ags.geometry.MapPoint;
            import com.esri.ags.layers.ArcGISDynamicMapServiceLayer;
            import mx.events.FlexEvent;
            protected function myURL_creationCompleteHandler(event:FlexEvent):void
                var myDynamicService:ArcGISDynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer();
                myDynamicService.url = "http://gis-server/ArcGis/rest/services/" + myURL.selectedItem + "/MapServer";
                myDynamicService.name = myURL.selectedItem;
                MyML.addLayer(myDynamicService);
    </fx:Script>
    <esri:Map id="MyML" width="100%" height="100%" />
    <s:DropDownList id="myURL" selectedIndex="0" creationComplete="myURL_creationCompleteHandler(event)">
        <s:ArrayList>
            <fx:String>Highway</fx:String>
        </s:ArrayList>
    </s:DropDownList>
</s:Application>
Don't forget to click the Mark as answer check and to click the top arrow (promote) as shown below:
MohammedIsmail
hi
thanks for your kind help
i do have one more problem hope u can help me
as am using dropdownlist box for loading map services of different places like
when i select any service from the list it is getting displayed some where
suppose if load Africa service then i want to load india then ...
am unable to clear the privious coordinate so that i can able to load other service at same place (i.e center of the screen)
        <s:ArrayList>
            <fx:String>India</fx:String>
            <fx:String>Africa</fx:String>
            <fx:String>Austrelia</fx:String>
            <fx:String>USA</fx:String>
        </s:ArrayList>
    </s:DropDownList>
Thanks & Regards
ISMAIL
Ismail,
Try this:
    <fx:Script>
        <![CDATA[
    </fx:Script>
        <s:ArrayList>
        </s:ArrayList>
    </s:DropDownList>
</s:Application>
Ismail,
   So you would change the myURL_creationCompleteHandler function to this then:
                switch(myURL.selectedItem){
                    case "India":{
                        MyML.centerAt(new MapPoint(70.0,6.0));
                        break;
                case "Africa":{
                    MyML.centerAt(new MapPoint(80.0,12.0));
                    break;
Now your questions have been answered so It is time you mark this thread as answered.
(follow the images directions left to right on the post that answered your question)
MohammedIsmail
hi Robert
Sorry to disturb you again
its not working after loading first service when i select second its not getting updated with second service
i have searched for refresh, clear option could't find
     case "Raichur":
     MyML.centerAt(new MapPoint(76.90,16.12));
     break;
     case "Yadgir":
     MyML.centerAt(new MapPoint(76.88,16.89));
     break;
Thanks
Ismail
Ismail,
   This has been tested and works:
    <fx:Script>
        <![CDATA[
            [Bindable] private var layerCount:int = 0;
            protected function myURL_creationCompleteHandler(event:Event):void
                if(!MyML.getLayer(myURL.selectedItem)){
                    myDynamicService.name = myDynamicService.id = myURL.selectedItem;
                    myDynamicService.addEventListener(LayerEvent.LOAD, setMapCenter);
                    layerCount++;
                }else{
                    setMapCenter(null);
            private function setMapCenter(evt:Event):void
                    case "Raichur":{
                        break;
                    case "Yadgir":{
                        break;
    </fx:Script>
    <s:DropDownList id="myURL" selectedIndex="0" creationComplete="myURL_creationCompleteHandler(event)" change="myURL_creationCompleteHandler(event)">
        <s:ArrayList>
        </s:ArrayList>
    </s:DropDownList>
    <s:Label text="{layerCount}" x="200" y="3" />
</s:Application>
Ismail,
   You forgot the do the most important part... Mark the thread as answered. See the image and follow the steps left to right.
