Disabling the editor popup
1487
01-29-2013 01:00 AM
ab1
Is there any way to disable the popup of the editor from showing when I click on a feature to be edited?
Regards.
ronaldmcfarlane
Have you looked at the EditWithoutEditor.mxml, in samples (http://resources.arcgis.com/en/help/flex-api/samples/index.html#/Edit_without_Editor/01nq00000043000... )?  If it is a specific use, then hard coding in the feature service isn't a problem and drop some of the added functionality so nothing shows.
ronaldmcfarlane
A little more information in your question would be helpful.  I assume you have the Editor open because you want to edit the feature.  I assume you want to edit the specific feature because you clicked on it with the Editor widget active.  The pop-up lets you edit attributes and/or attachments, thus I assume you don't want to do that.  So I am going to guess you want to edit the feature by moving or deleting it.  To select a feature without clicking on it, you use the selectfeatures tool from the Editor tool bar and either click on the item or draw a box around the feature to select it without opening the popup.  You could then move or delete the feature (again assuming you had permission to do so).  I hope this helps.
ab1
Thanks Ronald for the reply.
The editor is hidden. It doesn't appear in the application. I want the user to be able only to move features by clicking on them. The inconvenient is that when a feature is clicked, the attributes popup appears. I want to remove that behaviour.
I don't want the user to use a selection tool in order to modify features.
Is there any other solution?
ronaldmcfarlane
What is your Flex and ArcGIS Server versions?
ronaldmcfarlane
