Disable editing capabilites of a layer
1608
05-25-2011 01:36 PM
JasonTrook
Greetings,
I am looking to disable editing capabilities for some of my feature layers.  I modified the sample code 'Editor with toolbar' to display my project layers.  However, I only want to some of the layers to be editable and others read only.  Is there a way to do this?
My overall goal is to:
1) show both editable/non-editable layers in Legend w/ label & symbology
2) if a user tries to select non-editable layer a warning message appears
3) have info window enabled so a user can still retrieve info from non-editable features
With respect to #3 I currently get two windows to appear, 1 with the draw/edit tool and 1 with the info window.
Thanks in advance,
Jason
BjornSvensson
Esri Alum
Yes, you can have non-editable feature layers. When you add your feature layers, point it to a layer within a MapService instead of a layer within a FeatureService.
"The feature layer can be used to display features from one single layer of either a Feature Service or a Map Service. The layer can be either a (spatial) layer or a (non-spatial) table. The features in a FeatureLayer can be edited if it is based on a Feature Service."
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/layers/FeatureLayer.html
JasonTrook
Great, that makes sense.
I now have two legends: one displaying my Map Services and one displaying my editable Feature Services (see graphic).  Is there a good way to combine the two into a single legend (1st choice) or somehow stack one on top of the other.  So far I can't manage to reduce to size of the legend to fill up only a portion of the screen width/height.  Thanks,
Jason
by Anonymous User
Not applicable
Jason
What about adding the map service that has everything  (use that for the legend) then when someone wants to edit load the feature service?
