Delete Indisvidual graphics?
4958
12
02-12-2013 12:59 PM
ionarawilson1
I have a tool that creates labels (graphics) when the user clicks on a button and then on the map. Is there a way to delete these labels one by one? Thank  you!!!  Here is the code:
 private function addtext():void  {       myMap.addEventListener(MapMouseEvent.MAP_CLICK, onClickFunction);      }       private function onClickFunction(event:MapMouseEvent):void       {            const mapPoint:MapPoint = event.mapPoint;    mapPoint.spatialReference = new SpatialReference(102100);            var myGraphicMarker:Graphic = new Graphic(mapPoint, new TextSymbol(labeltext.text,null,0x000000,1, tsBorder.selected,tsBorderColor.selectedColor,tsBackground.selected,tsColor2.selectedColor,placement.selectedItem,angle.value,xoffset.value,yoffset.value,new TextFormat(myFont.selectedItem, tfSize.value, tsColor1.selectedColor, tfBold.selected,tfItalic.selected, tfUnderline.selected),      null,null));    theTextGraphic = myGraphicMarker        //myGraphicMarker.toolTip = "Marker added with ActionScript";    pointGraphicsLayer.add(theTextGraphic);    pointGraphicsLayer.refresh();      }
MarkHoyland
I added in creationComplete of the application,
but it could be with the map's creationComplete.
Here is the full test app. (this was is with 2.5 arc gis flex api. The textSymbol for latest api is slightly different with an alpha parameter. I added a commented textSymbol which should work with newer api, but untested by me.).
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"        xmlns:s="library://ns.adobe.com/flex/spark"        xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" xmlns:esri="http://www.esri.com/2008/ags"       creationComplete="application1_creationCompleteHandler(event)">  <fx:Script>   <![CDATA[    import com.esri.ags.Graphic;    import com.esri.ags.events.MapMouseEvent;    import com.esri.ags.geometry.MapPoint;    import com.esri.ags.symbols.TextSymbol;        import mx.events.FlexEvent;            //[Bindable]     private var graphicContextMenu:ContextMenu = new ContextMenu();        protected function application1_creationCompleteHandler(event:FlexEvent):void    {     graphicContextMenu.hideBuiltInItems();     var item:ContextMenuItem;     item = new ContextMenuItem("Delete me");     //item.enabled = true;     item.addEventListener(ContextMenuEvent.MENU_ITEM_SELECT, deleteGraphic_handler);     graphicContextMenu.customItems.push(item);    }        protected function deleteGraphic_handler(event:ContextMenuEvent):void    {     trace("deleteGraphic_handler");     if (event.contextMenuOwner is Graphic)     {      var graphic:Graphic = event.contextMenuOwner as Graphic;      graphic.graphicsLayer.remove(graphic);     }    }        protected function map_mapClickHandler(event:MapMouseEvent):void    {     const mapPoint:MapPoint = event.mapPoint;          var textSymbol:TextSymbol = new TextSymbol("myTextSymbol",null,0x000000, true,0,true); //2.5 api     //var textSymbol:TextSymbol = new TextSymbol("myTextSymbol",null,0x000000, 1, true,0,true); // newer api               var myGraphicMarker:Graphic = new Graphic(mapPoint, textSymbol);          myGraphicMarker.contextMenu = graphicContextMenu;          graphicsLayer.add(myGraphicMarker);     graphicsLayer.refresh();    }                   ]]>  </fx:Script>  <fx:Declarations>   <!-- Place non-visual elements (e.g., services, value objects) here -->  </fx:Declarations>       <esri:Map id="map" mapClick="map_mapClickHandler(event)" >   <esri:extent>    <esri:Extent xmin="-10753431" ymin="4624151" xmax="-10737799" ymax="4635884">     <esri:SpatialReference wkid="102100"/>    </esri:Extent>   </esri:extent>   <esri:ArcGISTiledMapServiceLayer id="baseLayer" url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/>   <esri:GraphicsLayer id="graphicsLayer"/>  </esri:Map>     </s:Application>
IvanBespalov
by the same way like you just added it using remove() function
myGaphicsLayer.remove(myTextGraphic)
remove() method
public function remove(graphic:Graphic):void
Removes the specific graphic.
Parameters
graphic:Graphic �?? The graphic to remove.
See also
com.esri.ags.events.GraphicEvent.GRAPHIC_REMOVE
ionarawilson1
Thank you Ivan. The issue is that when I have two labels, it will delete the first one added although I clicked on the second label added and also if there are more than 2, like six, it will delete 3 labels when I click in just one label. If I create 3 labels, it will delete two and so forth...Any ideas why? Here is my code: thanks
//code called when user clicks a button
    private function deletedonetext():void
    myMap.removeEventListener(MapMouseEvent.MAP_CLICK, onClickFunction);
    labelmapbutton.selected = false;
    deletelabelmapbutton.selected = false;
    movelabelmapbutton.selected = false;
    myEditTool2.deactivate();
    myMap.addEventListener(MapMouseEvent.MAP_CLICK, onClickFunction2);
   protected function onClickFunction2(event:MouseEvent):void
    var grProvider:ArrayCollection = pointGraphicsLayer.graphicProvider as ArrayCollection;
    for each (var gr:Graphic in grProvider)
     pointGraphicsLayer.remove(gr);
ionarawilson1
And if I have the following code it will delete the first label I select only
    pointGraphicsLayer.remove(theTextGraphic);
KenBuja
MVP Esteemed Contributor
Try this
    pointGraphicsLayer.remove(event.target);
ionarawilson1
I tried that Ken but it did not work. I used the following code and nothing happens when I click on a graphic:
  var graphic2:Graphic = event.currentTarget as Graphic
    pointGraphicsLayer.remove(graphic2);
KenBuja
I made a slight modification to the Adding Graphics sample and it seems to work properly. Maybe it's because I used the graphic layer's click event and event.target instead of event.currentTarget
               pageTitle="Adding graphics using MXML and/or ActionScript">
    <s:layout>
        <s:VerticalLayout horizontalAlign="center" paddingTop="3"/>
    </s:layout>
    <fx:Script>
        <=!=[=C=D=A=T=A=[
            import com.esri.ags.SpatialReference;
            import com.esri.ags.symbols.PictureMarkerSymbol;
            private function addSomeMarkers():void
                // This is just to show how to add markers
                // using ActionScript code as opposed to MXML tags.
                var myGraphicMarker:Graphic = new Graphic(new MapPoint(1447100, 7477200, new SpatialReference(102100)),
                    new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_DIAMOND, 22, 0x009933));
                myGraphicsLayer.add(myGraphicMarker);
                // PictureMarker - embedded image
                [Embed('assets/globe.png')]
                var picEmbeddedClass:Class;
                var pictureMarker:PictureMarkerSymbol = new PictureMarkerSymbol(picEmbeddedClass);
                var myGraphicPic:Graphic = new Graphic(new MapPoint(-411000, 4924000, new SpatialReference(102100)));
                myGraphicPic.symbol = pictureMarker;
                myGraphicsLayer.add(myGraphicPic);
                var myPolyline:Polyline = new Polyline(
                        new MapPoint(-1726185, 9543036),
                        new MapPoint(34923, 6920940),
                        new MapPoint(1874303, 6255632),
                        new MapPoint(1835168, 6255632),
                        new MapPoint(1913439, 6138225)
                    ]], new SpatialReference(102100));
                var myGraphicLine:Graphic = new Graphic(myPolyline);
                myGraphicLine.symbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASH, 0xDD2222, 1.0, 4)
                myGraphicsLayer.add(myGraphicLine);
                var myPolygon:Polygon = new Polygon(
                        new MapPoint(2352491, -1992338),
                        new MapPoint(2332923, -2461967),
                        new MapPoint(2646009, -2266288),
                        new MapPoint(3076503, -2324992),
                        new MapPoint(3272181, -2520670),
                        new MapPoint(3506996, -2559806),
                        new MapPoint(3702675, -3049003),
                        new MapPoint(3370021, -3675175),
                        new MapPoint(2763416, -4046965),
                        new MapPoint(2117676, -4144804),
                        new MapPoint(1961133, -3890422),
                        new MapPoint(2000269, -3655607),
                        new MapPoint(1667615, -3185978),
                        new MapPoint(1550208, -2422831),
                        new MapPoint(1334961, -1953202),
                var myGraphicPolygon:Graphic = new Graphic();
                myGraphicPolygon.geometry = myPolygon;
                myGraphicPolygon.symbol = new SimpleFillSymbol(
                    SimpleFillSymbol.STYLE_SOLID, // fill style
                    0xFF0000, // fill color
                    0.7 // fill alpha
                myGraphicPolygon.toolTip = "Polygon added with ActionScript";
                myGraphicsLayer.add(myGraphicPolygon);
                btn.enabled = false;
            protected function myGraphicsLayer_clickHandler(event:MouseEvent):void
                myGraphicsLayer.remove(event.target as Graphic);
    </fx:Script>
    <s:Label width="100%" text="This sample demonstrates adding graphics to the map using either MXML or ActionScript.  Simple marker symbols, picture marker symbols, simple line symbols, simple fill symbols, and picture fill symbols are shown."/>
    <s:Button id="btn"
              click="addSomeMarkers()"
              label="Add some more markers using ActionScript"/>
    <esri:Map id="myMap"
              level="2"
              wrapAround180="true">
        <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/>
        <esri:GraphicsLayer id="myGraphicsLayer" click="myGraphicsLayer_clickHandler(event)">
            <esri:Graphic toolTip="California MapPoint with a SimpleMarkerSymbol">
                <esri:geometry>
                    <esri:MapPoint x="-13163000" y="4035000"
                                   spatialReference="{new SpatialReference(102100)}"/>
                </esri:geometry>
                <esri:symbol>
                    <esri:SimpleMarkerSymbol color="0x0033DD" size="18"/>
                </esri:symbol>
            </esri:Graphic>
            <esri:Graphic toolTip="Hurricane polyline with a SimpleLineSymbol">
                <esri:geometry>
                    <esri:Polyline spatialReference="{new SpatialReference(102100)}">
                        <fx:Array>
                            <fx:Array>
                                <esri:MapPoint x="-4700503" y="1128848"/>
                                <esri:MapPoint x="-7909635" y="2819513"/>
                                <esri:MapPoint x="-8144450" y="4199048"/>
                                <esri:MapPoint x="-7244327" y="5261584"/>
                            </fx:Array>
                        </fx:Array>
                    </esri:Polyline>
                </esri:geometry>
                <esri:symbol>
                    <esri:SimpleLineSymbol width="6" color="0xFF0000"/>
                </esri:symbol>
            </esri:Graphic>
            <esri:Graphic toolTip="Brazilian polygon with a SimpleFillSymbol">
                <esri:geometry>
                    <esri:Polygon spatialReference="{new SpatialReference(102100)}">
                        <fx:Array>
                            <fx:Array>
                                <esri:MapPoint x="-3867905" y="-671044"/>
                                <esri:MapPoint x="-4533702" y="-2578326"/>
                                <esri:MapPoint x="-5316417" y="-2832708"/>
                                <esri:MapPoint x="-5844750" y="-3869806"/>
                                <esri:MapPoint x="-6333947" y="-3498016"/>
                                <esri:MapPoint x="-6412218" y="-1942370"/>
                                <esri:MapPoint x="-8211974" y="-954779"/>
                                <esri:MapPoint x="-7703209" y="229077"/>
                                <esri:MapPoint x="-5736637" y="454597"/>
                            </fx:Array>
                        </fx:Array>
                    </esri:Polygon>
                </esri:geometry>
                <esri:symbol>
                    <esri:SimpleFillSymbol alpha="0.7" color="0x009933"/>
                </esri:symbol>
            </esri:Graphic>
        </esri:GraphicsLayer>
    </esri:Map>
</s:Application>
ionarawilson1
When I use this code
pointGraphicsLayer.remove(event.target as Graphic);
and I debug, I find that two variables are throwing errors:
movementX - exception thrown by getter
movementY - exception thrown by getter
And the error is ReferenceError: Error #1069: Property movementX not found on flash.events.MouseEvent and there is no default value.
Any  idea why this is happening? Is it because my mappoint is not a predetermined one but based on the event's map point of the function that added the graphic?
    null,null));
ionarawilson1
It is like not recognizing the graphic as a target to the click event
MarkHoyland
You could add a context menu to the graphic. ie right click on the graphic and choose "delete"
