Defining Custom Pointer
1328
01-31-2011 05:49 AM
AlexanderStepanov
Hi All:
I am trying to define some custom pointers for my tools.
( for example toggling map.openHandCursorVisible property will change between "openHand/pan" and "regular" cursor.). I would like to add 2 additional types. Should I work with cursor manager directly in Flex or using AGS Flex API?
I will appreciate if you could point me out to documentation/examples where this issue is discussed.
Kind regards,
Alexander
AndyGup
Alexander,
Try something like this. Create your own png image and then:
[Embed('../images/i_pointer_cursor.png')]
private var _pointerCursor:Class;
map.cursorManager.setCursor(_pointerCursor,2,0,-3);
If you want access to default cursors you can try something like this:
Mouse.cursor = MouseCursor.ARROW;
-Andy
Esri Developer Network Team
AlexanderStepanov
Andy, thank you!
I will try it.
Kind regards,
Alexander
Alexander,
-Andy
