Date / Time entry - two questions
932
03-08-2011 09:57 AM
JonPedder
Hi, I have a couple of questions I'm hoping to get some help with. Below is the code in question.
<esri:FeatureLayer id="resourceStatus"
  visible="{toggleResourceStatus.selected}"
  mode="onDemand"
  graphicAdd="resourceStatus_graphicAddHandler(event)"
  outFields="*"
  url="http://sarserver/MapSAR_Server/rest/services/MapSARFlex/FeatureServer/2"/>
1) Rather than display ALL fields "*" I???d like to just display specific fields. I'm having a problem with syntax I think, what would the correct syntax be?
2) I have a 'Date' field which is displaying in editor but it only gives me the option to enter a date via the picker not time. How would I allow entry of date and time?
Thanks so much for your help
Jon
JonPedder
Ah, i eventually figured out my first question, I had the syntax incorrect.
I used outFields="[field1,field2,etc]" and that worked.
I'm still stuck on Q2
Looking to be able to input both date and time into the date field displayed using the above code.
RobertScheitlin__GISP
Jon,
   I just talked to Bjorn (esri API Team) and this is not possible without customization currently.
JonPedder
Thanks for checking. Ouch. is there any way to enter time, even without a popup?
JonPedder
I just added a dummy text field to hold time, for now anyway. Thanks
